So I have accidentally corrupted a sandisk usb drive. When I go to Disks & Devices, the usb is not detected there. I can access it only through kde partition manager or the terminal but I am unable to read any data in it. It is supposed to be 64GB but in kde partition manager, the capacity is shown as 64MB. I tried creating a new partition table, it shows success but the partition table doesn't get created. It still prompts me to create a new partition table. How do I make the usb drive usable? I don't care if the data is lost.
I tried the previous answer to a similar question How to format a USB drive?
It didn't work for me. Here is the output when executing those commands.
❯ lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0         7:0    0     4K  1 loop /snap/bare/5
loop1         7:1    0  72.9M  1 loop /snap/core22/509
loop2         7:2    0  72.9M  1 loop /snap/core22/522
loop3         7:3    0 452.4M  1 loop /snap/gnome-42-2204/56
loop4         7:4    0 460.3M  1 loop /snap/gnome-42-2204/65
loop5         7:5    0  91.7M  1 loop /snap/gtk-common-themes/1535
loop6         7:6    0  49.8M  1 loop /snap/snapd/17950
loop7         7:7    0  49.8M  1 loop /snap/snapd/18357
sda           8:0    1    64M  0 disk
nvme0n1     259:0    0 476.9G  0 disk
├─nvme0n1p1 259:1    0   260M  0 part /boot/efi
├─nvme0n1p2 259:2    0    16M  0 part
├─nvme0n1p3 259:3    0 200.9G  0 part
├─nvme0n1p4 259:4    0     1G  0 part
├─nvme0n1p5 259:5    0   2.2G  0 part
├─nvme0n1p6 259:6    0   252G  0 part /
└─nvme0n1p7 259:7    0  20.6G  0 part
❯ sudo fdisk /dev/sda
Welcome to fdisk (util-linux 2.37.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command.
Device does not contain a recognized partition table. Created a new DOS disklabel with disk identifier 0xf430b9ec.
Command (m for help): o Created a new DOS disklabel with disk identifier 0xd9afc416.
Command (m for help): n Partition type p primary (0 primary, 0 extended, 4 free) e extended (container for logical partitions) Select (default p): p Partition number (1-4, default 1): 1 First sector (2048-131071, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (2048-131071, default 131071):
Created a new partition 1 of type 'Linux' and of size 63 MiB.
Command (m for help): w The partition table has been altered. Calling ioctl() to re-read partition table. Syncing disks.
❯ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS loop0 7:0 0 4K 1 loop /snap/bare/5 loop1 7:1 0 72.9M 1 loop /snap/core22/509 loop2 7:2 0 72.9M 1 loop /snap/core22/522 loop3 7:3 0 452.4M 1 loop /snap/gnome-42-2204/56 loop4 7:4 0 460.3M 1 loop /snap/gnome-42-2204/65 loop5 7:5 0 91.7M 1 loop /snap/gtk-common-themes/1535 loop6 7:6 0 49.8M 1 loop /snap/snapd/17950 loop7 7:7 0 49.8M 1 loop /snap/snapd/18357 sda 8:0 1 64M 0 disk nvme0n1 259:0 0 476.9G 0 disk ├─nvme0n1p1 259:1 0 260M 0 part /boot/efi ├─nvme0n1p2 259:2 0 16M 0 part ├─nvme0n1p3 259:3 0 200.9G 0 part ├─nvme0n1p4 259:4 0 1G 0 part ├─nvme0n1p5 259:5 0 2.2G 0 part ├─nvme0n1p6 259:6 0 252G 0 part / └─nvme0n1p7 259:7 0 20.6G 0 part
Even though fdisk says a new partition was created, when rechecking afterwards with lsblk it doesn't show any new partition.
