I'm trying to install clamav and when I'm running sudo apt-get install clamav clamav-daemon -y
The output is:
root@server:/etc/apt# apt-get install clamav
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: libclamav9 : Depends: libtfm1 (>= 0.13) but it is not installable E: Unable to correct problems, you have held broken packages.
I already tried:
sudo apt update
sudo apt upgrade
Then this:
sudo apt --fix-broken install
And this (which gives blank output):
sudo dpkg --get-selections | grep hold
And none of these commands helped.
I also checked my sources.list, and it seems to be ok. I also tried to remove this packages, but I only have "these packages are not installed". Any suggestions?
Andrew
