libcuinj64-11.5 : Depends: libnvidia-compute-495 (>= 495) but it is not going to be installed or
libnvidia-compute-495-server (>= 495) but it is not installable or
libcuda.so.1 (>= 495) or
libcuda-11.5-1
libnvidia-ml-dev : Depends: libnvidia-compute-495 (>= 495) but it is not going to be installed or
libnvidia-ml.so.1 (>= 495)
nvidia-cuda-dev : Depends: libnvidia-compute-495 (>= 495) but it is not going to be installed or
libcuda-11.5-1
Recommends: libnvcuvid1 but it is not installable
- 31,035
- 11
- 2
The problem arised at my side after upgrading to nvidia-driver-535 from the nvidia repository. I do not know if it is needed, but in this process I also got rid of dpkg --remove-architecture i386 first. So the process was:
WARNING! USE YOUR BRAIN!
If your system happens to be i386 following will kill your system.
apt-get --allow-remove-essential purge ".*:i386"
Then disable NVidia-Repositories (YMMV):
cd /etc/apt/sources.list.d
mv cuda-ubuntu2204-x86_64.list cuda-ubuntu2204-x86_64.list.disabled
apt update
cat cuda-ubuntu2204-x86_64.list.disabled
deb [signed-by=/usr/share/keyrings/cuda-archive-keyring.gpg] http://HTTPS///developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/x86_64/ /
http://HTTPS/// is there because I use
apt-cacher-ngextensively. This wayapt-cacher-ngis able to access the repositories viaHTTPS
Then purge every trace of 535 drivers and NVidia-Things:
Only purge what's not needed. Purging also removes configuration which might stay in the way. Or might contain valuable information.
Note that I did this over ssh from another computer, because this probably brings down X11 as well on the machine:
dpkg --get-selections | grep 535
dpkg --get-selections | grep nvidia
gives
apt purge WHATEVER..
Then I cleaned remainders which were not in the repository anymore
apt-show-versions | grep -v '/jammy'
For example
apt purge libxnvctrl0
Then I re-installed everything from the Ubuntu repository again:
apt install nvidia-driver-535 nvidia-cuda-toolkit nvidia-settings
Note that you probably need to install xserver-xorg-video-nvidia-535, too. I do not need it, the machine is a headless GPU server for pytorch.
Then reboot, and voila:
# nvcc -V
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Thu_Nov_18_09:45:30_PST_2021
Cuda compilation tools, release 11.5, V11.5.119
Build cuda_11.5.r11.5/compiler.30672275_0
# nvidia-smi
Mon Sep 11 20:20:20 2023
| NVIDIA-SMI 535.86.05 Driver Version: 535.86.05 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4090 Off | 00000000:01:00.0 Off | Off |
| 0% 40C P8 6W / 450W | 3MiB / 24564MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
Final notes:
My systems are highly automated. For example snap, dkms, initrd etc. are all done by configuration management scripts, such that I do not need to think of things like this myself. Perhaps you need some additional steps for updating initrd or dkms before reboot, but I think this is all handled by apt the right way. (But I cannot be sure.)
- 780
- 1
- 7
- 18
