I need to let you know, the screen on this HP stream is broken, and an external monitor is in use. I understand that a new laptop is needed, I have to use this one for now. I am learning a new language, Kotlin, ad used jdkman.io to download the cli. When I rebooted, it will only reboots into Ubuntu 23.04 tty1-6. I have researched everywhere and tried everything to switch back to the normal interface. All I get is a black screen. When I say everything, I mean everything. What Ithink happened is, right before that, I cleaned up the storage and accidently removed my KDE plasma or something. Because when I do the things I have found to do I get either a error or a black screen.
Another thing to note, I can not connect to my network and there is not Ethernet port. When I go about that with directions I have found, I get an error. So is there anything that can get me back to my normal desktop environment? When I first boot up it does show the Ubuntu studio logo, then it goes to the tty1.
Sorry, let me clear some things up in my question.
- I am 100% sure I removed KDE Plasma, although when I try and reinstall, there is no network. I do have a bootable flash, since screen is broken, I can't boot from bios using an external monitor, or I am lacking that opportunity on this machine. If I could boot the flash drive(USB) using the command-line, that would do the trick.
When I use ps -ef ! Grep -l tty, I get (standard input).
This may narrow the problem down also. Let's say I just worked with what I have and tried to open a project in Android Studio, like I would in my normal desktop terminal. It says unable to detect graphics environment.
