Sometimes I download .avif images from the Internet. I would like the thumbnails of these images to appear in Files (nautilus). How do I enable thumbnails for AVIF images? Also, can I enable thumbnails for JXL images, HEIF images and HEIC images?
Asked
Active
Viewed 2,980 times
The convert tool from imagemagick can be used to create thumbnails for AVIF images:
- First, install
imagemagick:sudo apt install imagemagick - Next, create a folder named
thumbnailersin~/.local/share.mkdir -p ~/.local/share/thumbnailers - Then, create a file named
avif.thumbnailerin that folder.nano ~/.local/share/thumbnailers/avif.thumbnailer - Copy the following lines into the file (use Ctrl+C to copy, Ctrl+Shift+V to paste into
nanowindow):[Thumbnailer Entry] Exec=/usr/bin/convert %i[0] -thumbnail %sx%s png:%o MimeType=image/avif; - Press Ctrl+O and Enter to save the file, and Ctrl+X to exit
nano. - Finally, fully close the file manager (Nautilus in your case) with:
nautilus -q
AVIF images should have their thumbnails the next time you open the file manager.
Notes:
- I have only tested this on Ubuntu 22.04.3. On earlier releases,
imagemagickmight not support AVIF images, according to this thread. - Also on Ubuntu 22.04,
imagemagick(v.6.9.11.60) does seem to support HEIC images:
However, I don't have any HEIC or HEIF images to test, so I can't be sure. You might want to trying putting the MIME types of those files into the$ identify -list format | grep --ignore-case heic AVIF* HEIC rw+ AV1 Image File Format (1.12.0) HEIC* HEIC rw+ Apple High efficiency Image Format (1.12.0)avif.thumbnailerfile and see if it works, for example:[Thumbnailer Entry] Exec=/usr/bin/convert %i[0] -thumbnail %sx%s png:%o MimeType=image/avif;image/heic;image/heic-sequence;image/heif;image/heif-sequence;
Calico Cat
- 1,456
gThumb supports these image types since version 3.12. To install this program, run:
sudo apt install gthumb
It will install partial thumbnail support automatically. You might need to log out and log in again before this takes effect. Alternatively, you can try restarting the Files (nautilus) application by running:
nautilus --quit
It seems that the thumbnails are only created once Gthumb runs. So, to get the thumbnails to run, you need to open at least one of the images in the directory in Gthumb, and then it will create the thumbnails in the background.
Flimm
- 44,031
