I am running Ubuntu 20.04 on ARM board (aarch64). I want to log total power consumption every 5 seconds. I tried several tools.
Powertop
I tried running powertop command. It outputs something like following:
PowerTOP v2.11    Overview   Idle stats   Frequency stats   Device stats   Devic
Summary: 432.8 wakeups/second, 0.0 GPU ops/seconds, 0.0 VFS ops/sec and 14.7% C
Power est. Usage Events/s Category Description 322 mW 16.0 ms/s 75.2 Process [PID 1202] weston --idle- 239 mW 0.9 ms/s 60.1 kWork kernfs_notify_workfn 210 mW 9.7 ms/s 49.4 kWork memlat_monitor_work 146 mW 2.2 ms/s 36.0 Process [PID 11] [rcu_preempt] 121 mW 12.4 ms/s 25.8 Process [PID 1160] weston --idle- 91.4 mW 2.3 ms/s 22.2 Process [PID 12] [rcuog/0] 73.0 mW 12.8 ms/s 13.4 Interrupt [407] msm_drm 68.9 mW 237.3 µs/s 17.3 kWork def_work_fn 56.6 mW 2.4 ms/s 13.4 Timer tick_sched_timer 55.0 mW 1.7 ms/s 13.3 Timer hrtimer_wakeup 50.6 mW 120.4 µs/s 12.8 Timer histtimer_fn 46.7 mW 4.3 ms/s 10.1 Process [PID 2547] /home/ideaforg 29.6 mW 0.7 ms/s 7.2 Interrupt [31] apps_rsc 24.3 mW 1.1 ms/s 5.7 Process [PID 949] /usr/sbin/rsysl 23.0 mW 10.0 ms/s 1.9 Process [PID 462] /lib/systemd/sy 21.8 mW 1.9 ms/s 4.8 Process [PID 2571] /home/ideaforg 20.1 mW 6.6 ms/s 2.5 Process [PID 1] /sbin/init
But it does not seem to give single number for total power consumption.
Powerstat
I also tried to log power consumption using powerstat command:
# powerstat
Running for 300.0 seconds (30 samples at 10.0 second intervals).
Power measurements will start in 180 seconds time.
Time User Nice Sys Idle IO Run Ctxt/s IRQ/s Watts 08:55:57 0.3 0.0 0.8 98.9 0.0 2 1162 716 0.00 08:56:07 0.3 0.0 0.9 98.8 0.0 1 1220 784 0.00 08:56:17 0.3 0.0 1.1 98.6 0.0 1 1148 755 0.00 08:56:27 0.3 0.0 1.1 98.6 0.0 1 1272 804 0.00 ^C-------- ----- ----- ----- ----- ----- ---- ------ ------ ------ Average 0.3 0.0 1.0 98.7 0.0 1.2 1200.5 764.8 0.00 GeoMean 0.3 0.0 1.0 98.7 0.0 1.2 1199.5 764.1 0.00 StdDev 0.0 0.0 0.1 0.1 0.0 0.4 49.5 32.9 0.00
Minimum 0.3 0.0 0.8 98.6 0.0 1.0 1148.0 716.4 0.00 Maximum 0.3 0.0 1.1 98.9 0.0 2.0 1272.0 803.7 0.00
Summary: System: 0.00 Watts on average with standard deviation 0.00 Note: Power calculated from battery capacity drain, may not be accurate.
Somehow it keeps giving 0 watts.
Fetching from /sys/class/power_supply sub directory:
Reference
I started looking at various sub-directories /sys/class/power_supply. I have connected this device to DC power supply (It does not run on battery). So, I first had a look at sys/class/power_supply/dc directory:
# cd /sys/class/power_supply/
ls
battery dc pc_port usb
cd dc
ls
current_max input_current_limit present uevent waiting_for_supplier device online subsystem voltage_max wakeup24 hwmon0 power type voltage_now
cd power/
ls
autosuspend_delay_ms wakeup wakeup_expire_count control wakeup_abort_count wakeup_last_time_ms runtime_active_time wakeup_active wakeup_max_time_ms runtime_status wakeup_active_count wakeup_prevent_sleep_time_ms runtime_suspended_time wakeup_count wakeup_total_time_ms
But I did not find any file that might contain current power consumption. Then I tried to find in pc_port directory:
# cd /sys/class/power_supply/pc_port
ls
current_max hwmon2 power type voltage_max wakeup26 device online subsystem uevent waiting_for_supplier
cd power/
ls
I still did not find any sensible file name that might indicate to contain current power consumption.
How can I obtain current total power consumption?
RajS
  • 183
Speaking on the power devices builtin statistics reporting capabilities level, not all devices support providing statistics ... Use the upower command of UPower to list power devices with the option -e like so(this is a demonstration on a test system):
$ upower -e
/org/freedesktop/UPower/devices/line_power_ADP0
/org/freedesktop/UPower/devices/battery_BAT0
/org/freedesktop/UPower/devices/DisplayDevice
Then check the information of the device you want with the option -i ... Names are pretty descriptive, so the direct power line:
$ upower -i /org/freedesktop/UPower/devices/line_power_ADP0
  native-path:          ADP0
  power supply:         yes
  updated:              Fri 11 Aug 2023 03:45:32 PM +03 (68 seconds ago)
  has history:          no
  has statistics:       no
  line-power
    warning-level:       none
    online:              yes
    icon-name:          'ac-adapter-symbolic'
and as you can see, it doesn't have statistics ... So, information about current power consumption (among other information) can't be pulled from that device.
While the battery:
$ upower -i /org/freedesktop/UPower/devices/battery_BAT0
  native-path:          BAT0
  vendor:               LGC
  model:                L16L2PB2
  serial:               5545
  power supply:         yes
  updated:              Fri 11 Aug 2023 03:47:33 PM +03 (2 seconds ago)
  has history:          yes
  has statistics:       yes
  battery
    present:             yes
    rechargeable:        yes
    state:               charging
    warning-level:       none
    energy:              5.06 Wh
    energy-empty:        0 Wh
    energy-full:         17.99 Wh
    energy-full-design:  30 Wh
    energy-rate:         9.238 W
    voltage:             7.744 V
    charge-cycles:       N/A
    time to full:        1.4 hours
    percentage:          28%
    capacity:            59.9667%
    technology:          lithium-polymer
    icon-name:          'battery-low-charging-symbolic'
  History (charge):
    1691758053  28.000  charging
  History (rate):
    1691758053  9.238   charging
does have statistics and among those is energy-rate: which you can isolate and format for printing with something like this:
$ upower --show-info /org/freedesktop/UPower/devices/battery_BAT0 |
awk '/energy-rate:/{print $2}'
10.828 # <--- output
However, the statistics update interval might vary and updated: shows the time the statistics were last updated, but you can force statistics refresh of a certain device with for example:
busctl call org.freedesktop.UPower \
/org/freedesktop/UPower/devices/battery_BAT0 \
org.freedesktop.UPower.Device Refresh
and you can pull for e.g. energy-rate every for example three seconds with something like this:
while sleep 3
do
# Refresh device statistics
# Query the device statistics
upower -i /org/freedesktop/UPower/devices/battery_BAT0 |
done
Raffa
  • 34,963
