I have tried Calibre to convert an epub file to pdf, following https://askubuntu.com/a/299752/
ebook-convert /tmp/1.epub 1.pdf
but it fails with many errors.
$ ebook-convert --version
..ebook-convert-wrapped-wrapped (calibre 5.42.0)
Created by: Kovid Goyal <kovid@kovidgoyal.net>
I have also tried pandoc, following both https://askubuntu.com/a/798129/
$ pandoc -f epub -t pdf /tmp/1.epub -o 1.pdf
Error producing PDF.
! LaTeX Error: Unicode character − (U+2212)
               not set up for use with LaTeX.
See the LaTeX manual or LaTeX Companion for explanation. Type H <return> for immediate help. ...
l.12696 ...lationship between two things (from −
and https://askubuntu.com/a/954582/
$ pandoc -s -t latex --toc --chapters --latex-engine=lualatex /tmp/1.epub -o 1.pdf
--chapters has been removed. Use --top-level-division=chapter instead.
--latex-engine has been removed.  Use --pdf-engine instead.
Try pandoc --help for more information.
$ pandoc -s -t latex --toc --top-level-division=chapter --pdf-engine=lualatex /tmp/1.epub -o 1.pdf Error producing PDF. ! LaTeX Error: Not in outer par mode.
l.15624 \end{figure}}
Mine is:
$ pandoc --version
pandoc 2.17.1.1
Compiled with pandoc-types 1.22.2, texmath 0.12.4, skylighting 0.12.3,
citeproc 0.6.0.1, ipynb 0.2
User data directory: /home/t/.local/share/pandoc
Copyright (C) 2006-2022 John MacFarlane. Web:  https://pandoc.org
This is free software; see the source for copying conditions. There is no
warranty, not even for merchantability or fitness for a particular purpose.
Have I used both tools correctly? How would you convert the epub file to pdf?
andrew.46
  • 39,359
Tim
  • 26,107
