root@x# dmesg | grep rename
[ 3.127628] r8169 0000:01:00.0 enp1s0: renamed from eth0
[ 5.302161] r8188eu 1-1:1.0 wlx10feed2673c7: renamed from wlan0
wf=wlx10feed2673c7
root@x# cat /etc/wpa_supplicant/wpa_supplicant.conf
country=au
update_config=1
ctrl_interface=/var/run/wpa_supplicant
network={
ssid="hi-fi"
psk=#########
connected using cmd
root@x# wpa_supplicant -B -D wext -c /etc/wpa_supplicant/wpa_supplicant.conf -i $wf
root@x# cat /etc/network/interfaces
This file describes the network interfaces available on your system
and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
The loopback network interface
auto lo
iface lo inet loopback
iface eth0 inet dhcp
auto wlx10feed2673c7
allow-hotplug wlx10feed2673c7
iface wlx10feed2673c7 inet dhcp
is my /etc/network/interfaces is correct what is standard process of connecting wifi and "auto connect in future" (eg, reboot or wifi out of reange, then again in range) ???
or I have to use as it is?
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
wifi connected ok, but i want auto connect , on boot, on signal in range
