I do update my Ubuntu-22.04 desktop daily. Yesterday (2023-08-09) a new version of initramf-tools got installed. It is version 0.140ubuntu13.4.
I do check every day the origin of all installed packages via apt-cache policy (package) and via apt show (package). The version above doesn't seem to be available within the official repos any more.
How shall I continue?
  • Uninstall version 0.140ubuntu13.4 and reinstall the previous version?
  • Ignore the situation?
+ apt-cache policy initramfs-tools
initramfs-tools:
  Installed: 0.140ubuntu13.4
  Candidate: 0.140ubuntu13.4
  Version table:
 *** 0.140ubuntu13.4 100
        100 /var/lib/dpkg/status
     0.140ubuntu13.2 500
        500 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
     0.140ubuntu13 500
        500 http://archive.ubuntu.com/ubuntu jammy/main amd64 Packages
+ apt show initramfs-tools
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Package: initramfs-tools Version: 0.140ubuntu13.4 Status: install ok installed Priority: optional Section: utils Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com> Original-Maintainer: Debian kernel team <debian-kernel@lists.debian.org> Installed-Size: 152 kB Provides: linux-initramfs-tool Depends: initramfs-tools-core (= 0.140ubuntu13.4), linux-base Suggests: bash-completion Conflicts: linux-initramfs-tool, usplash (<< 0.5.50) Breaks: e2fsprogs (<< 1.42.13), initscripts (<< 2.88dsf-59.3~), netplan.io (<< 0.37), upstart Download-Size: unknown APT-Manual-Installed: no APT-Sources: /var/lib/dpkg/status Description: generic modular initramfs generator (automation) This package builds a bootable initramfs for Linux kernel packages. The initramfs is loaded along with the kernel and is responsible for mounting the root filesystem and starting the main init system.
A.L
  • 531
From all available information so far, it seems this packages was in Phased Updates and reached 20%, and was then pulled back.
This most likely means that some of the first users to get this packages ran into one or more bugs that were considered serious enough to roll back the update (I haven't yet identified which bugs these are).
The recommended action in this case would probably be to roll back to the previous version.
This can be done with apt by specifying the exact version you want to install:
sudo apt-get install initramfs-tools=0.140ubuntu13.2 initramfs-tools-bin=0.140ubuntu13.2 initramfs-tools-core=0.140ubuntu13.2
This should downgrade back to the current version, and will output the following without any errors: (output from --dry-run)
Reading package lists... Done
Building dependency tree... Done
The following packages will be DOWNGRADED:
  initramfs-tools initramfs-tools-bin initramfs-tools-core
0 upgraded, 0 newly installed, 3 downgraded, 0 to remove and 0 not upgraded.
Inst initramfs-tools [0.140ubuntu13.4] (0.140ubuntu13.2 Ubuntu:22.04/jammy-updates [all]) []
Inst initramfs-tools-core [0.140ubuntu13.4] (0.140ubuntu13.2 Ubuntu:22.04/jammy-updates [all]) []
Inst initramfs-tools-bin [0.140ubuntu13.4] (0.140ubuntu13.2 Ubuntu:22.04/jammy-updates [amd64])
Conf initramfs-tools (0.140ubuntu13.2 Ubuntu:22.04/jammy-updates [all])
Conf initramfs-tools-core (0.140ubuntu13.2 Ubuntu:22.04/jammy-updates [all])
Conf initramfs-tools-bin (0.140ubuntu13.2 Ubuntu:22.04/jammy-updates [amd64])
EDIT:The initial response from the package maintainer seems to indicate that the release was pulled because of a scheduling conflict with point release 22.04.3, and thus not pointing to any serious bug. I'll follow up on this - see here.
EDIT2: FWIW, it seems initramfs-tools 0.140ubuntu13.4 is back in the release pocket of the repositories.
Artur Meinild
  • 31,035
As of 8/17/2023, that version is back in the official repos for 22.04
initramfs-tools:
  Version table:
 *** 0.140ubuntu13.4 500 (phased 10%)
        500 http://us.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
        500 http://us.archive.ubuntu.com/ubuntu jammy-updates/main i386 Packages
     0.140ubuntu13 500
        500 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 Packages
        500 http://us.archive.ubuntu.com/ubuntu jammy/main i386 Packages
