pipx vs. pip
pipx(Install and Run Python Applications in Isolated Environments) is not an equal alternative to pip(The Python Package Installer) ... It uses pip and works differently too … It isolates the apps/packages it downloads ... So, they are not made available to system Python outside that isolated environment ... It creates a separate virtual environment for each app it installs … Its main purpose, however, is to make Python apps run-able as regular commands from the command-line in the console/terminal and not to make them available(importable) to your Python interpreter.
However, this(using the pip Python3 module):
python3 -m pip install -U panflute
run either system-wide(not advised) or inside a virtual environment(preferred) should install and update that package so it could be imported by the interpreter.
Ubuntu 23.04+
That said, you are using Ubuntu 23.04(later releases included) on which system-wide Python packages installation is prohibited(by default) via Python package managers like pip and handed over to the release package managers like APT to comply with PEP 668 – Marking Python base environments as “externally managed” ... You should see an error message like this when trying to use pip(other Python package managers included) to install a system-wide(i.e. outside a virtual environment) package:
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
If you wish to install a non-Debian packaged Python application,
it may be easiest to use pipx install xyz, which will manage a
virtual environment for you. Make sure you have pipx installed.
See /usr/share/doc/python3.11/README.venv for more information.
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
However, the suggested package naming in:
install.
is merely a suggestion and doesn't necessarily mean that the package has been already made available in the Ubuntu official repositories ... Therefore, you should confirm its availability first with something like:
$ apt search python3-panflute
Sorting... Done
Full Text Search... Done
Unfortunately, as you can see that package is not available yet(at least from the official repositories).
Workarounds
Your best choice to install Python3 packages that are not yet available through APT(usually under the name python3-packagename), is to do that from inside a Python3 virtual environment that you create and use the method to install with pip described above.
Creating and using a virtual environment is not really that difficult be it in scripts or in the terminal … Please see for example:
Note: There is the other option to pass both these two option --user --break-system-packages to pip which will force the package install … This although limited to user environment, but is not considered safe and might still do what it says will do i.e. --break-system-packages so not advised either.
