-1
I follow the steps to install VS code on Chromebook amd64 (https://code.visualstudio.com/blogs/2020/12/03/chromebook-get-started) and get stuck on double-click on the package to launch the installer.
I see: Install app with Linux Installation successfully started. Details Application: code Version: 1.81.0-1690979901 Description: Code editing. Redefined. Visual Studio Code is a new choice of tool that combines the simplicity of a code editor with what developers need for the core edit-build-debug cycle. See https://code.visualstudio.com/docs/setup/linux for installation instructions and FAQ.
I click OK and see Error installing Linux application
code: Depends: libasound2 (>= 1.0.17) but it is not installable
    Depends: libatk-bridge2.0-0 (>= 2.5.3) but it is not installable
    Depends: libatk1.0-0 (>= 2.2.0) but it is not installable
    Depends: libatspi2.0-0 (>= 2.9.90) but it is not installable
    Depends: libc6 (>= 2.17) but it is not installable
    Depends: libcairo2 (>= 1.6.0) but it is not installable
    Depends: libcurl3-gnutls but it is not installable or
             libcurl3-nss but it is not installable or
             libcurl4 but it is not installable or
             libcurl3 but it is not installable
    Depends: libdbus-1-3 (>= 1.0.2) but it is not installable
    Depends: libdrm2 (>= 2.4.60) but it is not installable
    Depends: libexpat1 (>= 2.0.1) but it is not installable
    Depends: libgbm1 (>= 17.1.0~rc2) but it is not installable
    Depends: libglib2.0-0 (>= 2.12.0) but it is not installable
    Depends: libglib2.0-0 (>= 2.39.4) but it is not installable
    Depends: libgssapi-krb5-2 but it is not installable
    Depends: libgtk-3-0 (>= 3.9.10) but it is not installable
    Depends: libgtk-3-0 (>= 3.9.10) but it is not installable or
             libgtk-4-1 but it is not installable
    Depends: libkrb5-3 but it is not installable
    Depends: libnspr4 (>= 2:4.9-2~) but it is not installable
    Depends: libnss3 (>= 2:3.22) but it is not installable
    Depends: libnss3 (>= 3.26) but it is not installable
    Depends: libpango-1.0-0 (>= 1.14.0) but it is not installable
    Depends: libsecret-1-0 (>= 0.18) but it is not installable
    Depends: libstdc++6 (>= 5) but it is not installable
    Depends: libstdc++6 (>= 5.2) but it is not installable
    Depends: libstdc++6 (>= 6) but it is not installable
    Depends: libx11-6 but it is not installable
    Depends: libx11-6 (>= 2:1.4.99.1) but it is not installable
    Depends: libxcb1 (>= 1.9.2) but it is not installable
    Depends: libxcomposite1 (>= 1:0.4.4-1) but it is not installable
    Depends: libxdamage1 (>= 1:1.1) but it is not installable
    Depends: libxext6 but it is not installable
    Depends: libxfixes3 but it is not installable
    Depends: libxkbcommon0 (>= 0.4.1) but it is not installable
    Depends: libxkbfile1 but it is not installable
    Depends: libxrandr2 but it is not installable
    Recommends: libvulkan1 but it is not installable
I mean, I understand nothing. I would just like to set up local web dev environment to start coding after codecademy course and web says my Chromebook should install VS Code and all other dependencies.
Pleeease if anyone could advice i would be more than grateful! karo
ok so I removed Linux dev environment and installed it again, adding sudo apt-get -f install and then following the steps from here https://linuxize.com/post/how-to-install-visual-studio-code-on-debian-10/ on how to install VS Code on Debian10. No idea if thats what i was meant to do, but works.
If i double click on the file from the downloads, the errors are still same as before. I launched VS Code from the command line with 'code'.
If anyone has any idea what just happened feel free to share.
andrew.46
  • 39,359
Karo
Try
or use aptitude to fix co dependencies
