August 3-4 Ubuntu offered an update. It was not at all clear going in that it was a major version change, being a jump in major Linux version from 5.19 to 6.2. At first it booted as usual with a notification in 'system tray' that reported broken packages. I followed the suggestion to remove and reinstall those packages and was left with a box that will only boot into command line mode. Furthermore, reversion to previous version fails in the same way: no NVIDIA drivers available where they used to be.
Using recovery mode menu to run dpkg tells me there are no packages available for NVIDIA GeForce video card, and libglmesa. Also Zoom fwiw.
I would prefer not to start from scratch here. Anyone have any helpful pointers on how to patch this back up?
Date: 4 August 2023
Event: Ubuntu driven auto upgrade From Linux 5.19 to 6.2 in jammy 22.04LTS
Video card: NVIDIA GeForce
Drivers missing: NVIDIA 470 series, and others
Answer (h/t Rinzwind)
Reinstalling the desktop:
apt-get install --reinstall ubuntu-desktop
Applied at the command prompt in the newer version, it restored the use of the desktop on both the updated version with Linux 6.2 and the previous version with Linux 5.19.
Jammy is unjammed!
Not sure if this ha been resolved. Standard Nouveau drivers were the only option for my system.
Could be that you're Nvidia card is not supported in the update/kernel revision. I have an LGR580 and the Nvidia GT130M graphics card has no support past 5.15 I believe.
Standard Nouveau drivers were the only thing that worked, unfortunately. Try rolling back the video driver from terminal. You should be able to boot to repair.
Please check out this post to switch back to the Nouveau driver from boot terminal...
Remove nVidia driver and go back to Nouveau
Hope that helps.
Same happened here. Fix was:
sudo dpkg --configure -a
sudo apt-get install --reinstall ubuntu-desktop
Then logout and back in.
sotirov
  • 4,379
Dan
  • 16
