I am having a lot of trouble with a Western Digital 6TB external drive since I've first used in a year or so ago.
To begin with, I was getting into the world of servers and was making use of an old laptop with Ubuntu Server OS mainly for just hosting a Plex media server. All of that media is on this external drive. To begin with, I used my Windows computer to copy many of the several terabytes of media, but once I mounted it to Ubuntu it will only allow ownership to be root.
I have recently learned a lot more about servers and picked up a used Dell Precision Workstation and had a fresh install of Ubuntu Server 22.04.2 LTS and tried mounting it to user and not root, but still have the same issue. I have other internal and external drives and drive pools that I can change ownership whenever and permissions the same way.
I have looked at all of the questions where some people are not familiar with how to change permissions or ownerships, but I have tried all different ways. I have tried to change permissions and ownerships with the drive mounted and unmounted. I would really like to be able to change the ownership so that I can use it through Samba like my other drives or even SFTP. I will put some information below that might be helpful if anyone has any ideas.
Another fun fact is that the Server won't boot into the OS while the drive is plugged in (and yes I have checked for any boot flags on the partitions), so I have to plug it in after the server OS boots.
$ blkid /dev/sdm1 (Output):
/dev/sdm1: LABEL="My Book" UUID="E01F-6997" BLOCK_SIZE="512" TYPE="exfat" PARTLABEL="My Book" PARTUUID="ace84bbc-8a6d-462b-b543-0f5f65457510"
$ df -H (Output):
Filesystem Size Used Avail Use% Mounted on
tmpfs 3.4G 5.1M 3.4G 1% /run
/dev/sda2 983G 717G 216G 77% /
tmpfs 17G 189k 17G 1% /dev/shm
tmpfs 5.3M 0 5.3M 0% /run/lock
tmpfs 17G 0 17G 0% /run/qemu
External2Pool 8.2T 1.4T 6.5T 17% /mnt/ext2Pool
/dev/sdi1 738G 29k 700G 1% /mnt/ePool5
/dev/sdj1 984G 29k 934G 1% /mnt/ePool7
/dev/sde1 2.0T 286G 1.6T 16% /mnt/ePool1
/dev/sdg1 984G 29k 934G 1% /mnt/ePool2
/dev/sdh1 2.0T 300G 1.6T 17% /mnt/ePool3
/dev/sdk1 245G 29k 233G 1% /mnt/ePool6
/dev/sdl1 314G 29k 298G 1% /mnt/ePool4
/dev/sda1 1.2G 6.4M 1.2G 1% /boot/efi
/dev/sdf1 2.1T 1.7T 306G 85% /mnt/JoDrive
tmpfs 3.4G 25k 3.4G 1% /run/user/1000
/dev/sdb1 984G 321M 934G 1% /mnt/iPool1
/dev/sdc1 984G 321M 934G 1% /mnt/iPool2
/dev/sdd1 492G 29k 467G 1% /mnt/iPool3
Internal2Pool 2.5T 642M 2.4T 1% /mnt/int2Pool
/dev/sdm1 6.1T 5.4T 638G 90% /mnt/MAIN
$ fdisk /dev/sdm (Output):
Welcome to fdisk (util-linux 2.37.2).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
[?2004hCommand (m for help): p
[?2004l
Disk /dev/sdm: 5.46 TiB, 6001174511616 bytes, 11721043968 sectors
Disk model: My Book 25ED
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 3FA9CA38-7310-44E6-8972-1B2B5B8FC0DC
Device Start End Sectors Size Type
/dev/sdm1 2048 11721041919 11721039872 5.5T Linux filesystem
Here is my fstab:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda2 during curtin installation
/dev/disk/by-uuid/4b40d9bb-a2cb-48d7-84db-1f193caab897 / ext4 defaults 0 1
# /boot/efi was on /dev/sda1 during curtin installation
/dev/disk/by-uuid/CF6E-0CFC /boot/efi vfat defaults 0 1
/swap.img none swap sw 0 0
Original Plex Media Disks
Mom's Drive (2TB)
UUID=66728AB8728A8C8D /mnt/JoDrive ntfs defaults,nofail 0 0
Media Drive (6TB)
UUID=E01F-6997 /mnt/MAIN exfat defaults,nofail 0 0
(OLD) Drives for ePool (External)
My Storage Drive 1
UUID=4bcd5ddf-92b8-4c57-a359-c081f43a33e8 /mnt/ePool1 ext4 defaults,nofail 0 0
Storage Drive 2
UUID=4b974804-1c20-43bc-b857-c9fa42b75e7b /mnt/ePool2 ext4 defaults,nofail 0 0
Storage Drive 3
UUID=ae7418f3-d555-4f63-a4bf-cb1d74b9468b /mnt/ePool3 ext4 defaults,nofail 0 0
My Storage Drive 4
UUID=d2495930-ee12-462b-be34-bc29a120bce6 /mnt/ePool4 ext4 defaults,nofail 0 0
Storage Drive 5
UUID=e256781d-0ecc-4074-a0d9-6ba92751e7e6 /mnt/ePool5 ext4 defaults,nofail 0 0
Storage Drive 6
UUID=bcd2f4a6-39f8-4ba9-aecf-48f42c5308b9 /mnt/ePool6 ext4 defaults,nofail 0 0
Storage Drive 7
UUID=e13ccb83-e65a-46f6-8320-4e5b7cd49e38 /mnt/ePool7 ext4 defaults,nofail 0 0
Disks for iPool (Internal)
Internal Drive Storage (1TB)
UUID=eaea4e5b-b9b0-45fe-8ffe-e1b3edfab434 /mnt/iPool1 ext4 defaults,nofail 0 0
Internal Drive Storage 2 (1TB)
UUID=6ae3d2df-651b-438e-91b4-170377ca89ea /mnt/iPool2 ext4 defaults,nofail 0 0
Internal Drive Storage 3 (500GB)
UUID=9bf0af4b-dcf3-48f6-8dae-d2bbb06f4737 /mnt/iPool3 ext4 defaults,nofail 0 0
Pools
External Drive Pool
/mnt/ePool* /mnt/ext2Pool fuse.mergerfs cache.files=auto-full,dropcacheonclose=true,category.create=mfs,moveonenospc=true,minfreespace=10G,fsname=External2Pool,nonempty 0 0
Internal Drive Pool
/mnt/iPool* /mnt/int2Pool fuse.mergerfs cache.files=auto-full,dropcacheonclose=true,category.create=mfs,moveonenospc=true,minfreespace=10G,fsname=Internal2Pool,nonempty 0 0
Internal Drive Pool
#/mnt/iPool* /mnt/5iPool fuse.mergerfs cache.files=auto-full,dropcacheonclose=true,category.create=mfs,moveonenospc=true,minfreespace=10G,fsname=Internal2Pool,nonempty 0 0
(OLd) Internal Drisk Pool
#/mnt/iPool* /mnt/int3Pool fuse.mergerfs cache.files=auto-full,dropcacheonclose=true,category.create=mfs,moveonenospc=true,minfreespace=5G,fsname=Internal3Pool,nonempty 0 0
Thanks in advance to anyone that has the answer, and if any more information is needed please let me know.
