I bought an Asus ROG Zephyrus m16. In Windows 11 it maintains a temperature between 35° and 45° while in Ubuntu 22.04 it maintains a temperature between 45° and 60°. Why does this happen? How can I improve this?
karel
  • 122,292
  • 133
  • 301
  • 332
I have same problem with my legion 5 (core i7 12700h & nvidia 3060m), my avg idle windows 11 temperature is ~30, and after using linux, the idle is 40-45 there's 2 thing that I do to make the temp back normal
Step 1: Add PPA GPU Drivers Repository to the System
sudo add-apt-repository ppa:graphics-drivers/ppa
Step 2: Identify GPU Model and Available Drivers ubuntu-drivers devices
Step 3: Install Nvidia Driver sudo apt install [driver_name] for example in my case nvidia-550
or the simple way if you don't use Nvidia on linux, you can switch the graphics mode to use iGPU only mode, so I do this on windows 11, on Lenovo vantage, then I restart and switch to ubuntu, and you don't need to repeat this step after turn off the laptop, unless you switch the graphic mode to use Hybrid auto mode on windows
