Ubuntu 20.04 LTS had Devede installed and worked fine. Updated to 22.04 LTS and this, and other programs (e.g. Audacious) disappeared, either immediately, or subsequently. Cannot re-install. Tried manually with Devede, get this:
$ sudo apt-get install devede
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies. devede : Depends: ffmpeg or mencoder but it is not installable Depends: mpv but it is not installable or vlc but it is not installable E: Unable to correct problems, you have held broken packages.
n.b. VLC is installed, and works.
I haven't a clue what this means.
ps ffmpeg won't install either, and a similar message appears. The GUI installation through Ubuntu or Gnome doesn't work, either, and provides no information at all.
Terrance
  • 43,712
