I'm using Vultr VPS to create ubuntu server but after installing Install SSH Key I cannot login by ssh anymore. It shows : Permission denied, please try again.
The password key is total correct.
I'm using MacOS. I created id_rsa.pub and copied key to Vultr reinstall ssh. I have used id_rsa.pub key for bitbucket service also.
So which is the reason I cannot login with root by using ssh anymore?
Thank you so much.
I update ssh log
ssh -v root@149.28.145.90
OpenSSH_9.0p1, LibreSSL 3.3.6
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 21: include /etc/ssh/ssh_config.d/* matched no files
debug1: /etc/ssh/ssh_config line 54: Applying options for *
debug1: Authenticator provider $SSH_SK_PROVIDER did not resolve; disabling
debug1: Connecting to 149.28.145.90 [149.28.145.90] port 22.
debug1: Connection established.
debug1: identity file /Users/macOS/.ssh/id_rsa type 0
debug1: identity file /Users/macOS/.ssh/id_rsa-cert type -1
debug1: identity file /Users/macOS/.ssh/id_ecdsa type -1
debug1: identity file /Users/macOS/.ssh/id_ecdsa-cert type -1
debug1: identity file /Users/macOS/.ssh/id_ecdsa_sk type -1
debug1: identity file /Users/macOS/.ssh/id_ecdsa_sk-cert type -1
debug1: identity file /Users/macOS/.ssh/id_ed25519 type -1
debug1: identity file /Users/macOS/.ssh/id_ed25519-cert type -1
debug1: identity file /Users/macOS/.ssh/id_ed25519_sk type -1
debug1: identity file /Users/macOS/.ssh/id_ed25519_sk-cert type -1
debug1: identity file /Users/macOS/.ssh/id_xmss type -1
debug1: identity file /Users/macOS/.ssh/id_xmss-cert type -1
debug1: identity file /Users/macOS/.ssh/id_dsa type -1
debug1: identity file /Users/macOS/.ssh/id_dsa-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_9.0
debug1: Remote protocol version 2.0, remote software version OpenSSH_8.2p1 Ubuntu-4ubuntu0.7
debug1: compat_banner: match: OpenSSH_8.2p1 Ubuntu-4ubuntu0.7 pat OpenSSH* compat 0x04000000
debug1: Authenticating to 149.28.145.90:22 as 'root'
debug1: load_hostkeys: fopen /Users/macOS/.ssh/known_hosts2: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts2: No such file or directory
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ssh-ed25519
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: SSH2_MSG_KEX_ECDH_REPLY received
debug1: Server host key: ssh-ed25519 SHA256:/xz7YYBmz0xghGR0TZEwSmr6z9kwBk1T15YwBeRaSv4
debug1: Host '149.28.145.90' is known and matches the ED25519 host key.
debug1: Found key in /Users/macOS/.ssh/known_hosts:1
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: rekey in after 134217728 blocks
debug1: get_agent_identities: bound agent to hostkey
debug1: get_agent_identities: ssh_fetch_identitylist: agent contains no identities
debug1: Will attempt key: /Users/macOS/.ssh/id_rsa RSA SHA256:+o1B9zpeliVSvqKYfstJb2WRGW55345340z6rXUSEvWnn0fX1+G0
debug1: Will attempt key: /Users/macOS/.ssh/id_ecdsa
debug1: Will attempt key: /Users/macOS/.ssh/id_ecdsa_sk
debug1: Will attempt key: /Users/macOS/.ssh/id_ed25519
debug1: Will attempt key: /Users/macOS/.ssh/id_ed25519_sk
debug1: Will attempt key: /Users/macOS/.ssh/id_xmss
debug1: Will attempt key: /Users/macOS/.ssh/id_dsa
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,sk-ssh-ed25519@openssh.com,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ecdsa-sha2-nistp256@openssh.com>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Offering public key: /Users/macOS/.ssh/id_rsa RSA SHA256:+o1B9zpeliVSvqKYtJb25445WRGW0z6344rXUSEvWnn0fX1+G0
debug1: Trying private key: /Users/macOS/.ssh/id_ecdsa
debug1: Trying private key: /Users/macOS/.ssh/id_ecdsa_sk
debug1: Trying private key: /Users/macOS/.ssh/id_ed25519
debug1: Trying private key: /Users/macOS/.ssh/id_ed25519_sk
debug1: Trying private key: /Users/macOS/.ssh/id_xmss
debug1: Trying private key: /Users/macOS/.ssh/id_dsa
Here is ssh config
PermitRootLogin yes
Include /etc/ssh/sshd_config.d/*.conf
PubkeyAuthentication yes
PasswordAuthentication yes
ChallengeResponseAuthentication no
UsePAM yes
X11Forwarding yes
PrintMotd no
AcceptEnv LANG LC_*
Subsystem sftp internal-sftp
AllowGroups admin
Hai Tien
  • 103
After Offering you should see the following, unless the key is wrong/old/invalid:
debug1: Offering public key: C:\\Users\\Luuk/.ssh/id_rsa RSA SHA256:4vcibbzSvFvASY6Yc**obscured**704
debug1: Server accepts key: C:\\Users\\Luuk/.ssh/id_rsa RSA SHA256:4vcibbzSvFvASY6Yc**obscured**704
debug1: Authentication succeeded (publickey).
Luuk
  • 286
