I recently received a Dell Precision 7820 with Ubuntu 20.04 pre-installed. After fully updating (and all was working), I upgraded to 22.04, but unfortunately, this has done something to prevent the OS-containing SSD from being visible on boot (but only sometimes...).
On booting via default settings, I'm greeted with:
ALERT! UUID=51139eac-d829-4030-8044-d1328bdfd2d3 does not exist. Dropping to a shell.
After which, I drop into an initramfs shell.
The punchline (which I arrived at after trying many many things) is this is kernel-dependent.
After enabling legacy boot via ROM in the BIOS (which I share only in case this matters) and ensuring that SATA is configured to use ACHI instead of RAID (as discussed in this question) I'm left with the following situation.
On boot and hitting ESC to offer up the Ubuntu GRUB options (I've now edited the GRUB info to show this by default, but including this so someone can reproduce what I did without that):
Ubuntu
Advanced options for Ubuntu
UEFI Firmware Settings
Restore OS to factory state
If I select Advanced options for Ubuntu and then boot into the 5.19.0-46 kernel (which is the default if I just select Ubuntu from the GRUB list), then this fails to mount and drop into initramfs.
HOWEVER, if I boot into the 5.15.0-76 kernel, Ubuntu starts fine with no issue.
Any help to explain this would be hugely appreciated. I'm seriously concerned that I don't understand why this is happening, which means I'm effectively pinned to 5.15.0-76 because, as of right now later kernels prevent OS loading!
Update in response to oldfred (July 21s)
============================== Boot Info Summary ===============================
=> No boot loader is installed in the MBR of /dev/nvme0n1.
=> libparted MBR boot code is installed in the MBR of /dev/sda.
nvme0n1p1: _____________________________________________________________________
File system: vfat
Boot sector type: Windows 8/10/11/2012: FAT32
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /efi/Boot/fbx64.efi /efi/Boot/mmx64.efi
/efi/ubuntu/grubx64.efi /efi/ubuntu/loadefi.efi
/efi/ubuntu/mmx64.efi /efi/ubuntu/shimx64.efi
/efi/ubuntu/UbuntuSecBoot.efi /efi/ubuntu/grub.cfg
nvme0n1p2: _____________________________________________________________________
File system: vfat
Operating System:
Boot files: /boot/grub/grub.cfg
nvme0n1p3: _____________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 22.04.2 LTS
Boot files: /boot/grub/grub.cfg /etc/fstab /etc/default/grub
sda1: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
sda2: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
================================ 1 OS detected =================================
OS#1: Ubuntu 22.04.2 LTS on nvme0n1p3
================================ Host/Hardware =================================
CPU architecture: 64-bit
Video: GA104GL [RTX A4000] EFI VGA from NVIDIA Corporation
BOOT_IMAGE of the installed session in use:
/boot/vmlinuz-5.15.0-76-generic root=UUID=51139eac-d829-4030-8044-d1328bdfd2d3 ro quiet splash vt.handoff=7
df -Th / : /dev/nvme0n1p3 ext4 1.9T 179G 1.6T 11% /
===================================== UEFI =====================================
BIOS/UEFI firmware: 2.32.1(2.32) from Dell Inc.
The firmware is EFI-compatible, and is set in EFI-mode for this installed-session.
SecureBoot disabled (confirmed by mokutil).
BootCurrent: 0007
Timeout: 1 seconds
BootOrder: 0007,0029,002A,002B,002C,002D,0000,0025,0026,0027,0028,0023
Boot0000* ubuntu_shimx64 NVMe(0x1,01-00-00-00-00-00-00-00)/HD(1,GPT,cf73badc-18d9-4b5f-afe6-5c279ce0d278,0x800,0x1a9000)/File(\EFI\ubuntu\shimx64.efi)
Boot0001* Diskette Drive BBS(Floppy,Diskette Drive,0x0)..BO
Boot0002* Internal HDD BBS(HD,Internal HDD,0x0)..BO
Boot0003* USB Storage Device BBS(USB,USB Storage Device,0x0)..BO
Boot0004* CD/DVD/CD-RW Drive BBS(CDROM,CD/DVD/CD-RW Drive,0x0)..BO
Boot0005* Onboard NIC BBS(Network,IBA CL Slot 00FE v0110,0x0)..BO
Boot0006* load_efi HD(1,GPT,cf73badc-18d9-4b5f-afe6-5c279ce0d278,0x800,0x1a9000)/File(\EFI\Ubuntu\loadefi.efi)
Boot0007* ubuntu HD(1,GPT,cf73badc-18d9-4b5f-afe6-5c279ce0d278,0x800,0x1a9000)/File(\EFI\ubuntu\shimx64.efi)
Boot0008* Onboard NIC(IPV4) PciRoot(0x0)/Pci(0x1f,0x6)/MAC(cc96e52d71d5,0)/IPv4(0.0.0.00.0.0.0,0,0)..BO
Boot0009* Onboard NIC(IPV6) PciRoot(0x0)/Pci(0x1f,0x6)/MAC(cc96e52d71d5,0)/IPv6([::]:<->[::]:,0,0)..BO
Boot000A* PXE IP4 Intel(R) Ethernet 10G 2P X710-T2L-t Adapter PciRoot(0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/MAC(b48351081138,1)/IPv4(0.0.0.00.0.0.0,0,0)..BO
Boot000B* PXE IP6 Intel(R) Ethernet 10G 2P X710-T2L-t Adapter PciRoot(0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/MAC(b48351081138,1)/IPv6([::]:<->[::]:,0,0)..BO
Boot000C* PXE IP4 Intel(R) Ethernet Network Adapter X710-TL PciRoot(0x1)/Pci(0x0,0x0)/Pci(0x0,0x1)/MAC(b48351081139,1)/IPv4(0.0.0.00.0.0.0,0,0)..BO
Boot000D* PXE IP6 Intel(R) Ethernet Network Adapter X710-TL PciRoot(0x1)/Pci(0x0,0x0)/Pci(0x0,0x1)/MAC(b48351081139,1)/IPv6([::]:<->[::]:,0,0)..BO
Boot0023* UEFI: Hard Drive HD(1,GPT,cf73badc-18d9-4b5f-afe6-5c279ce0d278,0x800,0x1a9000)/File(EFI\boot\bootx64.efi)..BO
Boot0025 PXE IP4 Intel(R) Ethernet 10G 2P X710-T2L-t Adapter PciRoot(0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/MAC(b48351081138,1)/IPv4(0.0.0.00.0.0.0,0,0)..BO
Boot0026 PXE IP6 Intel(R) Ethernet 10G 2P X710-T2L-t Adapter PciRoot(0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/MAC(b48351081138,1)/IPv6([::]:<->[::]:,0,0)..BO
Boot0027 PXE IP4 Intel(R) Ethernet Network Adapter X710-TL PciRoot(0x1)/Pci(0x0,0x0)/Pci(0x0,0x1)/MAC(b48351081139,1)/IPv4(0.0.0.00.0.0.0,0,0)..BO
Boot0028 PXE IP6 Intel(R) Ethernet Network Adapter X710-TL PciRoot(0x1)/Pci(0x0,0x0)/Pci(0x0,0x1)/MAC(b48351081139,1)/IPv6([::]:<->[::]:,0,0)..BO
Boot0029* Diskette Drive BBS(Floppy,Diskette Drive,0x0)..BO
Boot002A* HGST HUS726T4TALA6L0 BBS(HD,P0: HGST HUS726T4TALA6L0,0x0)..BO
Boot002B* USB Storage Device BBS(USB,USB Storage Device,0x0)..BO
Boot002C* CD/DVD/CD-RW Drive BBS(CDROM,CD/DVD/CD-RW Drive,0x0)..BO
Boot002D Onboard NIC BBS(Network,IBA CL Slot 00FE v0110,0x0)..BO
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
nvme0n1 : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, has-os, no-wind, 2048 sectors * 512 bytes
sda : notGPT, no-BIOSboot, has-noESP, not-usb, not-mmc, no-os, no-wind, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
nvme0n1p3 : is-os, 64, apt-get, signed grub-efi , grub2, grub-install, grubenv-ok, update-grub, farbios
nvme0n1p1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
sda2 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
sda1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
Partitions info (2/3): _________________________________________________________
nvme0n1p3 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
nvme0n1p1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
sda2 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
sda1 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
Partitions info (3/3): _________________________________________________________
nvme0n1p3 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, nvme0n1
nvme0n1p1 : not--sepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, nvme0n1
sda2 : maybesepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda
sda1 : maybesepboot, no---boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda
fdisk -l (filtered): ___________________________________________________________
Disk nvme0n1: 1.86 TiB, 2048408248320 bytes, 4000797360 sectors
Disk identifier: C926DE13-294F-4E1C-B428-0EFB34E21068
Start End Sectors Size Type
nvme0n1p1 2048 1742847 1740800 850M EFI System
nvme0n1p2 1742848 18520063 16777216 8G Microsoft reserved
nvme0n1p3 18520064 4000796671 3982276608 1.9T Linux filesystem
Disk sda: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk identifier: 0x5e6432b3
Boot Start End Sectors Size Id Type
sda1 2048 4032045055 4032043008 1.9T 83 Linux
sda2 4032045056 7814035455 3781990400 1.8T 83 Linux
parted -lm (filtered): _________________________________________________________
sda:4001GB:scsi:512:512:msdos:ATA HGST HUS726T4TAL:;
1:1049kB:2064GB:2064GB:ext4::;
2:2064GB:4001GB:1936GB:ext4::;
nvme0n1:2048GB:nvme:512:512:gpt:PC801 NVMe SK hynix 2TB:;
1:1049kB:892MB:891MB:fat32:EFI system partition:boot, esp;
2:892MB:9482MB:8590MB:fat32:Basic data partition:msftres;
3:9482MB:2048GB:2039GB:ext4::;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL
sda
├─sda1 ext4 d06f911f-9f8f-4218-9e4a-c0327d518b77 5e6432b3-01
└─sda2 ext4 fee50400-d622-4de9-aded-759a562617f5 5e6432b3-02
sdb
nvme0n1
├─nvme0n1p1 vfat 94F3-F0B1 cf73badc-18d9-4b5f-afe6-5c279ce0d278 ESP EFI system partition
├─nvme0n1p2 vfat 8819-913C b3c175c3-e3a0-4ef3-bea5-e11c2b133e84 OS Basic data partition
└─nvme0n1p3 ext4 51139eac-d829-4030-8044-d1328bdfd2d3 fa4918ab-47f2-4c7b-9eb5-de5999d37c73 UBUNTU
Mount points (filtered): _______________________________________________________
Avail Use% Mounted on
/dev/nvme0n1p3 1.6T 10% /
/dev/sda1 1.8T 0% /mnt/boot-sav/sda1
/dev/sda2 1.6T 0% /mnt/boot-sav/sda2
//storage1.ris.wustl.edu/alex.holehouse/Active 2.8T 89% /work
Mount options (filtered): ______________________________________________________
=================== nvme0n1p1/efi/ubuntu/grub.cfg (filtered) ===================
search.fs_uuid 51139eac-d829-4030-8044-d1328bdfd2d3 root
set prefix=($root)'/boot/grub'
configfile $prefix/grub.cfg
=================== nvme0n1p2/boot/grub/grub.cfg (filtered) ====================
Install Complete, remove media and reboot.
Dell Recovery
================= nvme0n1p2: Location of files loaded by Grub ==================
GiB - GB File Fragment(s)
?? = ?? boot/grub/grub.cfg 1
=================== nvme0n1p3/boot/grub/grub.cfg (filtered) ====================
Ubuntu 51139eac-d829-4030-8044-d1328bdfd2d3
Ubuntu, with Linux 5.19.0-46-generic 51139eac-d829-4030-8044-d1328bdfd2d3
Ubuntu, with Linux 5.15.0-76-generic 51139eac-d829-4030-8044-d1328bdfd2d3
END /etc/grub.d/30_os-prober
UEFI Firmware Settings uefi-firmware
END /etc/grub.d/30_uefi-firmware
======================== nvme0n1p3/etc/fstab (filtered) ========================
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/nvme0n1p3 during installation
UUID=51139eac-d829-4030-8044-d1328bdfd2d3 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/nvme0n1p1 during installation
UUID=94F3-F0B1 /boot/efi vfat umask=0077 0 1
/swapfile none swap sw 0 0
==================== nvme0n1p3/etc/default/grub (filtered) =====================
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=lsb_release -i -s 2> /dev/null || echo Debian
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
================= nvme0n1p3: Location of files loaded by Grub ==================
1738.973667145 = 1867.208757248 boot/grub/grub.cfg 1
158.686183929 = 170.387992576 boot/vmlinuz 1
477.052783966 = 512.231526400 boot/vmlinuz-5.15.0-76-generic 2
158.686183929 = 170.387992576 boot/vmlinuz-5.19.0-46-generic 1
477.052783966 = 512.231526400 boot/vmlinuz.old 2
253.857051849 = 272.576933888 boot/initrd.img 1
1677.781299591 = 1801.503952896 boot/initrd.img-5.15.0-76-generic 1
253.857051849 = 272.576933888 boot/initrd.img-5.19.0-46-generic 1
1677.781299591 = 1801.503952896 boot/initrd.img.old 1
=================== nvme0n1p3: ls -l /etc/grub.d/ (filtered) ===================
-rwxr-xr-x 1 root root 18683 Dec 18 2022 10_linux
-rwxr-xr-x 1 root root 43031 Dec 18 2022 10_linux_zfs
-rwxr-xr-x 1 root root 14387 Dec 18 2022 20_linux_xen
-rwxr-xr-x 1 root root 13369 Dec 18 2022 30_os-prober
-rwxr-xr-x 1 root root 1372 Dec 18 2022 30_uefi-firmware
-rwxr-xr-x 1 root root 700 Feb 20 2022 35_fwupd
-rwxr-xr-x 1 root root 214 Apr 15 2020 40_custom
-rwxr-xr-x 1 root root 215 Dec 18 2022 41_custom
-rwxr-xr-x 1 root root 1362 Jul 13 06:23 99_dell_recovery
==================== nvme0n1p3/etc/grub.d/99_dell_recovery =====================
#!/bin/bash -e
source /usr/lib/grub/grub-mkconfig_lib
cat << EOF
menuentry "Restore OS to factory state" {
search --no-floppy --hint '(hd0,gpt2)' --set --fs-uuid 8819-913C
set uuid_options="uuid=8819-913C"
if [ -s /factory/common.cfg ]; then
source /factory/common.cfg
else
set options="boot=casper automatic-ubiquity noprompt quiet splash nomodeset nopersistent"
fi
if [ -s /factory/post-rts-gfx.cfg ]; then
source /factory/post-rts-gfx.cfg
fi
if [ -s /factory/post-rts-wlan.cfg ]; then
source /factory/post-rts-wlan.cfg
fi
#Support starting from a loopback mount (Only support ubuntu.iso for filename)
if [ -f /ubuntu.iso ]; then
loopback loop /ubuntu.iso
set root=(loop)
set options="iso-scan/filename=/ubuntu.iso $options"
fi
if [ -n "${lang}" ]; then
set options="locale=$lang $options"
fi
if [ -s /factory/dual_enable ]; then
set options="dell-recovery/dual_boot=true $options"
fi
kernel=/casper/vmlinuz
if [ ! -f $kernel ]; then
kernel=/casper/vmlinuz.efi
fi
linux $kernel dell-recovery/recovery_type=hdd $uuid_options $options
initrd /casper/initrd
EOF
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility would reinstall the grub-efi of
nvme0n1p3,
using the following options: nvme0n1p1/boot/efi
Additional repair would be performed: unhide-bootmenu-10s use-standard-efi-file
Final advice in case of suggested repair: ______________________________________
Please do not forget to make your UEFI firmware boot on the Ubuntu 22.04.2 LTS entry (nvme0n1p1/efi/**/grub.efi (** will be updated in the final message) file) !
You show 4TB drive as DOS? Drives over 2TB must be gpt or they in past used some proprietary work around.
The 4 TB disk is partitioned into two separate partitions each under 2 TBs. No booting should be coming from here (and on a Live USB this disk is automatically mounted without issue when the Live USB starts). Output from gdisk below
sudo gdisk -l /dev/sda
GPT fdisk (gdisk) version 1.0.8
Partition table scan:
MBR: MBR only
BSD: not present
APM: not present
GPT: not present
Found invalid GPT and valid MBR; converting MBR to GPT format
in memory.
Disk /dev/sda: 7814037168 sectors, 3.6 TiB
Model: HGST HUS726T4TAL
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): 6FE8D04B-19DD-4F28-B8E0-6D9A12D769EA
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 7814037134
Partitions will be aligned on 2048-sector boundaries
Total free space is 3693 sectors (1.8 MiB)
Number Start (sector) End (sector) Size Code Name
1 2048 4032045055 1.9 TiB 8300 Linux filesystem
2 4032045056 7814035455 1.8 TiB 8300 Linux filesystem
Update in response to oldfred (July 24th)
Best to use UUID, not device as that can change.
Agreed, I have changed this back.
But your device entry does not look correct. You do not have p33 or thirty three partitions on NVMe drive.
Correct, sorry this was a typo in my answer which I've fixed
Root partition should also be 1 for pass parameter, so ext4 fsck can be run on boot.
I'm a confused by this comment; where do you see the pass parameter being not set to 1? In /etc/fstab the root partition has the pass parameter set to 1:
But maybe I'm missing something elsewhere?
Its drive size over 2TB must be gpt, not each partition. Not sure why you were even able to create that. But many advantages to gpt anyway.
To simply things I've deleted the sda partitions, such that the entire sda device is unallocated. This does not seem to change any of the behavior discussed above, but I figured it might rule out possible things. For completeness, the Boot-Repair output after this is linked here - I realize pasting would be better but the answer body becomes too long if pasted.
What video driver? And is it correctly installed from Ubuntu repository? Old install may have had it, update would not have automatically reinstalled it, and recovery mode uses nomodeset for video.
Using nvidia drivers that in the 5.15.0-76 kernel work absolutely fine (CUDA accessible, nvidia-smi works etc). Drivers are:
NVIDIA-SMI 525.125.06 Driver Version: 525.125.06 CUDA Version: 12.0 |
One thing to note: booting with debug added to the boot line shows that the difference between 5.15.0-76 and 5.19.0-46 is at the point where the boot drive is loaded. Bascically for 5.19 it hangs at
async_tx api initialized (async)
whereas for 5.15 this progress forward to:
EXT4-fs (nvme0n1p3): mounted file system
and then on.
I have messed around a lot with this, including setting rootdelay= to 60 to see if giving it more time will help, but no cigar.
Extra context that brought me here
It took me a lot of hours to get here, so I wanted to share some of the things I did
Initially checked that the 51139eac-d829-4030-8044-d1328bdfd2d3 device was not corrupted. I could boot via a live USB and mount the offending disk just fine. The disk is at /dev/nvme0n1p and the specific Ubuntu OS partition at /dev/nvme0n1p3, as expected for an SSD connected via NVME.
Output of blkid (run after mounting the from the Live USB)
$ blkid
/dev/nvme0n1p1: LABEL="ESP" UUID="94F3-F0B1" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="cf73badc-18d9-4b5f-afe6-5c279ce0d278"
/dev/nvme0n1p2: LABEL="OS" UUID="8819-913C" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="Basic data partition" PARTUUID="b3c175c3-e3a0-4ef3-bea5-e11c2b133e84"
/dev/nvme0n1p3: LABEL="UBUNTU" UUID="51139eac-d829-4030-8044-d1328bdfd2d3" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="fa4918ab-47f2-4c7b-9eb5-de5999d37c73"
/dev/sda1: UUID="d06f911f-9f8f-4218-9e4a-c0327d518b77" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="5e6432b3-01"
/dev/sda2: UUID="fee50400-d622-4de9-aded-759a562617f5" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="5e6432b3-02"
/dev/sdc1: BLOCK_SIZE="2048" UUID="2023-02-23-04-13-44-00" LABEL="Ubuntu 22.04.2 LTS amd64" TYPE="iso9660" PARTLABEL="ISO9660" PARTUUID="a0891d7e-b930-4513-94d8-f629dbd637b2"
/dev/loop1: TYPE="squashfs"
/dev/loop8: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
/dev/sdc2: SEC_TYPE="msdos" LABEL_FATBOOT="ESP" LABEL="ESP" UUID="F7DB-4D56" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="Appended2" PARTUUID="a0891d7e-b930-4513-94db-f629dbd637b2"
/dev/sdc4: LABEL="writable" UUID="168e1b81-4522-456d-955e-ffae6ecac2c8" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="a0829cd9-4a56-af45-87a1-0dc8d8fdd0ff"
/dev/loop7: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
and the output from fdisk is:
sudo fdisk -l
Disk /dev/loop0: 2.54 GiB, 2731876352 bytes, 5335696 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
... skipping loop1-loop7 for brevity
Disk /dev/nvme0n1: 1.86 TiB, 2048408248320 bytes, 4000797360 sectors
Disk model: PC801 NVMe SK hynix 2TB
Disklabel type: gpt
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1742847 1740800 850M EFI System
/dev/nvme0n1p2 1742848 18520063 16777216 8G Microsoft reserved
/dev/nvme0n1p3 18520064 4000796671 3982276608 1.9T Linux filesystem
Disk /dev/sda: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: HGST HUS726T4TAL
Disklabel type: dos
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 4032045055 4032043008 1.9T 83 Linux
/dev/sda2 4032045056 7814035455 3781990400 1.8T 83 Linux
Disk /dev/sdc: 7.5 GiB, 8053063680 bytes, 15728640 sectors
Disk model: Flash Disk
Disklabel type: gpt
Disk identifier: A0891D7E-B930-4513-94D9-F629DBD637B2
/dev/sdc1 64 9613459 9613396 4.6G Microsoft basic data
/dev/sdc2 9613460 9623527 10068 4.9M EFI System
/dev/sdc3 9623528 9624127 600 300K Microsoft basic data
/dev/sdc4 9625600 15728576 6102977 2.9G Linux filesystem
Disk /dev/loop8: 346.33 MiB, 363151360 bytes, 709280 sectors
And the content of fstab on the OS disk is
# note mount point defined from the live USB
cat /mnt/mydisk/etc/fstab
/etc/fstab: static file system information.
Use 'blkid' to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
#UUID=d06f911f-9f8f-4218-9e4a-c0327d518b77 /mnt/local1 ext4 defaults 0 0
#UUID=fee50400-d622-4de9-aded-759a562617f5 /mnt/local2 ext4 defaults 0 0
My boot mode is set to UEFI: Secure Boot Off, and from the BIOS I had checked the enable Legacy Boot ROM to load the USB mounter.
I also tried updating fstab to mount via the actual path (i.e. changing
To
/dev/nvme0n1p3 / ext4 errors=remount-ro 0 1
(NB this previously was written as nvme0n1p33 which was a typo on the answer)
Which also does not make a difference - loading in 5.15.0.76 works either way, and loading with 5.19.0.76 fails either way.
