I recently purchased a Lenovo Ideapad Flex 5. I instantly removed Windows 11 Home and installed Ubuntu 23.04. Only problem: the trackpad isn't working. Ubuntu doesn't even recognize the trackpad, as you can see from the lsusb output below:
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 0bda:4853 Realtek Semiconductor Corp. Bluetooth Radio
Bus 003 Device 003: ID 1c7a:0576 LighTuning Technology Inc. EgisTec EH576
Bus 003 Device 002: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 30c9:0053 Luxvisions Innotech Limited Integrated Camera
I've tried other linux distros; same problem. The trackpad works fine in the BIOS menu however, so I know it's not a hardware issue. I've looked everywhere online and I can't find anything.
Edit
This question is a duplicate but with no answer. Someone please help me, I really need this to work.Output of libinput list-devices:
Kernel: /dev/input/event3
Group: 1
Seat: seat0, default
Capabilities: keyboard
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Middle emulation: n/a
Calibration: n/a
Scroll methods: none
Click methods: none
Disable-w-typing: n/a
Disable-w-trackpointing: n/a
Accel profiles: n/a
Rotation: n/a
Device: Power Button
Kernel: /dev/input/event0
Group: 2
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: Lid Switch
Kernel: /dev/input/event1
Group: 3
Capabilities: switch
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: PixArt USB Optical Mouse
Kernel: /dev/input/event4
Group: 4
Capabilities: pointer
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: button
Click methods: none
Accel profiles: flat *adaptive
Rotation: n/a
Device: Integrated Camera: Integrated C
Kernel: /dev/input/event6
Group: 5
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: Ideapad extra buttons
Kernel: /dev/input/event5
Group: 6
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
Device: AT Translated Set 2 keyboard
Kernel: /dev/input/event2
Group: 7
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Calibration: n/a
Click methods: none
Accel profiles: n/a
Rotation: n/a
I ran sudo dmesg | grep modprobe after running sudo modprobe i2c-hid-acpi and got this:
[ 2.261372] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 2.273890] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[ 2.274501] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[ 2.275151] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[ 2.275783] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[ 2.280092] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.280232] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[ 2.280437] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 2.280591] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[ 2.280779] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.280932] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[ 2.293895] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.294095] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[ 3.880063] audit: type=1400 audit(1691009312.052:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=665 comm="apparmor_parser"
[ 3.880067] audit: type=1400 audit(1691009312.052:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=665 comm="apparmor_parser"
