when I run the sudo apt upgrade get this error.
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
when I run sudo dpkg --configure -a command system freeze at Skipping profile in /etc/apparmor.d/disable: usr.sbin.rsyslogdand ssh connection breaks after sometime.
root@beautiful-haslett:~# sudo dpkg --configure -a
Setting up apparmor (3.0.4-2ubuntu2.2) ... Reloading AppArmor profiles
