with the following instruction I have unfortunately my problems: How can I automatically copy the content of a usb (flash) drive to another directory?
I want that any USB stick/USB hard disk, which is connected to my computer, be copied automatically to a specific directory. Since the computer serves as a server, everything should happen by itself. Neither keyboard, mouse or monitor is connected.
If you know a program that can do this, you can of course tell me.
I have modified the script so far to my directories:
#!/usr/bin/env python3
import subprocess
import time
import shutil
target_folder = "/mnt/Sicherungen"
excluded = []
def get_mountedlist():
    return [(item.split()[0].replace("├─", "").replace("└─", ""),
             item[item.find("/"):]) for item in subprocess.check_output(
            ["/bin/bash", "-c", "lsblk"]).decode("utf-8").split("\n") if "/" in item]
def identify(disk):
    command = "find /dev/disk -ls | grep /"+disk
    output = subprocess.check_output(["/bin/bash", "-c", command]).decode("utf-8")
    if "usb" in output:
        return True
    else:
        return False
done = []
while True:
    mounted = get_mountedlist()
    new_paths = [dev for dev in get_mountedlist() if not dev in done and not dev[1] == "/"]
    valid = [dev for dev in new_paths if (identify(dev[0]), dev[1].split("/")[-1]  in excluded) == (True, False)]
    for item in valid:
        target = target_folder+"/"+item[1].split("/")[-1]
        try:
            shutil.rmtree(target)
        except FileNotFoundError:
            pass
        shutil.copytree(item[1], target)
    done = mounted
    time.sleep(4)
Unfortunately, however, it does not work afterwards and displays the following:
  Traceback (most recent call last):
File "/home/elias/Documents/copy_flash.py", line 29, in <module>
  File "/home/elias/Documents/copy_flash.py", line 29, in <listcomp>
  File "/home/elias/Documents/copy_flash.py", line 19, in identify
  File "/usr/lib/python3.10/subprocess.py", line 420, in check_output
    return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
  file "/usr/lib/python3.10/subprocess.py", line 524, in run
    raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['/bin/bash', '-c', 'find /dev/disk -ls | grep /loop0']' returned non-zero exit status 1.
I am brand new to Linux. I have never done anything like this before. I would be very grateful for some help.
