I am using a Logitech Trackman Marble Trackball on Ubuntu 22.04, Gnome Shell 42, Wayland.
I wish to simulate a middle mouse click with one of the extra side buttons, but it seems I am able to synthesize any type of button except the middle button.
  • I have created file at /etc/udev/hwdb.d/71-logitech-trackman.hwdb like so:
evdev:name:Logitech USB Trackball:*
 KEYBOARD_KEY_90004=btn_middle
I then run:
sudo systemd-hwdb update
sudo udevadm trigger
And physically reconnect the device.
  • Running sudo udevadm info /dev/input/event8 | grep btn_middle shows that the mapping has taken effect.
  • Running sudo evtest /dev/input/event8 outputs the correct mapping like so:
Event: time 1689266776.764313, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90004
Event: time 1689266776.764313, type 1 (EV_KEY), code 274 (BTN_MIDDLE), value 1
  • However, running sudo libinput debug-events --device /dev/input/event8 does not emit any output when I press the remapped button (though it does output correct lines for all other events).
Oddly, libinput does emit output if I choose any other target event, such as btn_left, btn_right, or even other buttons that the device does not have, such as btn_back, and these clicks are correctly reflected in the GUI. It appears to be only the middle button that cannot be emulated.
The behaviour is the same if I attempt to remap any of the four physical buttons.
What could be preventing the middle mouse button mapping from working?
I wanted to map side button to left. Here is what I did.
Created file /etc/udev/hwdb.d/99-mouse.hwdb:
evdev:input:b*v062Ap4101*
 KEYBOARD_KEY_90004=btn_left
Where v062Ap4101 is USB device ID from lsusb command. Note all hex numbers have to be uppercase.
Default mapping is:
 KEYBOARD_KEY_90001=btn_left
 KEYBOARD_KEY_90002=btn_right
 KEYBOARD_KEY_90003=btn_middle
 KEYBOARD_KEY_90004=btn_side
 KEYBOARD_KEY_90005=btn_extra
Then:
  • $ sudo systemd-hwdb update - to update the database
  • $ sudo udevadm trigger /sys/class/input/event9 - to reload database
  • $ sudo udevadm test /sys/class/input/event9 - to validate it worked
For testing and dubugging I used $ sudo libinput debug-events . You can get event device number and more. Hope it helps.
I have similar issue and i solve it, try change you .hwdb file:
evdev:input:*
