I had spent three days trying to fix this issue. I tried to follow these solutions. here, here and others but I could not fix this issue.
Some information about issue:
(initramfs) exit
Gave up waiting for root file system device. Common problems:
Boot args (cat /proc/cmdline)
Check rootdelay= (did the system wait long enough?) Missing modules (cat /proc/modules; ls /dev)
ALERT! UUID=C025f430-2b2f-40ec-b334-da8e827a9a51 does not exist. Dropping
BusyBox v1.30.1 (Ubuntu 1:1.30.1-4ubuntu6.4) built-in shell (ash) Enter 'help' for a list of built-in commands.
The output the help is.
(initramfs) help
Built-in commands:
: [ alias break cd chdir command continue echo eval exec exit export false getopts hash help history let local printf pwd read readonly return set shift test times trap true type ulimit umask unalias unset wait [ [[ acpid arch ash awk basename blockdev busybox cat chmod chroot chvt clear cmp cp cut date deallocvt deluser devmem df du dumpkmap echo egrep env expr false fbset fgrep find fold fstrim grep gunzip gzip hostname hwclock ifconfig ip kill in loadfont loadkmap is lzop mkdir mkfifo mknod mkswap mktemp modinfo more mount my nuke openvt pidof printf ps pwd readlink reboot reset rm rmdir run-init sed seq setkeycodes sh sleep sort stat static-sh stty switch_root sync tail tee test touch tr true tty umount uname uniq wc wget which yes
The output lsblk is: sh: lsblk: not found.
The output blkid is: /dev/sda1: LABEL="REDHWAN" UUID="1438-8EAB" TYPE="vfat" PARTUUID="03fbda08-01
The output reboot is nothing but it is working when add -f like : reboot -f. The output sudo is: sh: lsblk: not found.
The output fsck is: fsck from util-linux 2.34
The output: cat /proc/cmdline
BOOT_IMAGE=/vmlinuz-5.15.0-76-generic root=UUID=c025f430-2b2f-40ec-b334-da8e827a9a51 ro quiet splash.
The output: cat /proc/modules
hid_generic 16384 0 - Live 0xffffffffc00ef000
uas 28672 0 - Live 0xffffffffc00cc000
usbhid 65536 0 - Live 0xffffffffc013f000 usb_storage 77824 1 uas, Live 0xffffffffc0059000
hid 147456 2 hid_generic, usbhid, Live 0xffffffffc002b000
ahci 45056 0 - Live 0xffffffffc023a000
xhci_pci 24576 0 Live 0xffffffffc024d000
psmouse 176128 0 Live 0xffffffffc025a000
crc32_pclmul 16384 0 Live 0xffffffffc0232000
igc 159744 0 - Live 0xffffffffc01ff000
libahci 45056 1 ahci, Live 0xffffffffc01b6000
xhci_pci_renesas 20480 1 xhci_pci, Live 0xffffffffc01a0000
umi 32768 0 Live Oxffffffffc0073000
video 61440 0 Live 0xffffffffc001b000
The output: ls /dev
vga_arbiter
tty24
fuse
rfkill
tty25 tty26
ptmx
mem
ttyso
null
tty27
ttyS1
port
tty28
ttys2 ttys3
zero
tty29
full
tty30
ttyS4
random
tty31
ttys5
urandom
tty32
ttyS6
kmsg tty
tty33 tty34
ttys7 ttys8
console
tty35
ttys9
ttyo
tty36
ttyS10
VCS
tty37
ttyS11
VCSU
tty38
ttyS12
vcsa
tty39
ttyS13
VCS1 VCSU1
tty40 tty41
ttyS14
ttyS15
Avcsa1
tty42 tty43
ttyS16
ttyl
ttyS17
tty2
tty44
ttyS18
1tty3 tty4
tty45
ttyS19
tty46
ttys20
tty5 tty6
tty47
ttys21
tty48
ttys22
tty7 tty8
tty49
ttys23
tty50 tty51
ttys24
tty9
ttys25
tty52
ttys26
tty11 tty12
tty53
ttys27
tty54
ttys28
tty13
tty55
ttys29
tty14
tty56
ttys30
tty15
tty57 tty58 tty59
ttys31
tty16 tty17
ttyprintk
hpet
tty18
tty60
hurng
tty19
tty61
tpmo
tty20 tty21
tty62
tpmrmo
tty63
100p-control
tty22
snapshot
100p2
loop3
100p4
loop7
dma_heap udmabuf
net
ppp vfio
input
psaux
uinput
rtco
mapper
fbo
mcelog
cpu_dma latency
pts
core
fd
stdin
stdout
stderr
char
rtc
block
bus
ptpo
hidrawo
hidrawi
usb
hidrau
hidraug
bsg
sda
sda1
disk
hidraw4
No output for: cat /etc/fstab
The output: cat /boot/grub/grub.cfg
cat: can't open '/boot/grub/grub.cfg': No such file or directory.
REDHWAN
  • 193
It is fixed.
In my case, my PC is recent, and it has a button to press on it in order to restart the BIOS, similar to the router of WIFI.
REDHWAN
  • 193
