All of a sudden I cannot build a container requires access to archive.ubuntu.com. Here is my dockerfile:
FROM ubuntu:20.04
RUN apt update && apt install -y wget &&
wget -q https://packages.microsoft.com/config/ubuntu/20.04/packages-microsoft-prod.deb -O packages-microsoft-prod.deb &&
dpkg -i packages-microsoft-prod.deb &&
rm packages-microsoft-prod.deb &&
apt update &&
apt install -y dotnet-sdk-6.0 &&
apt install -y build-essential &&
apt install -y cmake &&
apt install -y libssl-dev &&
apt install -y libgpiod-dev &&
apt install -y libi2c-dev &&
apt install -y tmux &&
apt install -y systemctl &&
apt install -y git build-essential libjansson-dev libi2c-dev libgpiod-dev libsensors4-dev libz-dev libsystemd-dev
Going to archive.ubuntu.com in my browser does not seem quite right either. I can click on the ubuntu folder and it seems as if something may be broken. screenshot
I can keep clicking on Ubuntu and it just keeps going deeper.
Error that I get:
[+] Building 168.9s (6/11)
=> [internal] load .dockerignore 0.0s
=> => transferring context: 2B 0.0s
=> [internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 1.28kB 0.0s
=> [internal] load metadata for docker.io/library/ubuntu:20.04 0.3s
=> CACHED [1/8] FROM docker.io/library/ubuntu:20.04@sha256:c9820a44b950956a790c354700c1166a7ec648bc0d215fa438d3a339812f1d01 0.0s
=> [internal] load build context 0.4s
=> => transferring context: 1.55MB 0.4s
=> ERROR [2/8] RUN apt update && apt install -y wget && wget -q https://packages.microsoft.com/config/ubuntu/20.04/packages-microsoft-prod.d 168.6s
> [2/8] RUN apt update && apt install -y wget && wget -q https://packages.microsoft.com/config/ubuntu/20.04/packages-microsoft-prod.deb -O packages-microsoft-prod.deb && dpkg -i packages-microsoft-prod.deb && rm packages-microsoft-prod.deb && apt update && apt install -y dotnet-sdk-6.0 && apt install -y build-essential && apt install -y cmake && apt install -y libssl-dev && apt install -y libgpiod-dev && apt install -y libi2c-dev && apt install -y tmux && apt install -y systemctl && apt install -y git build-essential libjansson-dev libi2c-dev libgpiod-dev libsensors4-dev libz-dev libsystemd-dev:
#0 0.374
#0 0.374 WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
#0 0.374
#0 56.42 Err:1 http://archive.ubuntu.com/ubuntu focal InRelease
#0 56.42 Temporary failure resolving 'archive.ubuntu.com'
#0 56.44 Err:2 http://security.ubuntu.com/ubuntu focal-security InRelease
#0 56.44 Temporary failure resolving 'security.ubuntu.com'
#0 112.5 Err:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
#0 112.5 Temporary failure resolving 'archive.ubuntu.com'
#0 168.5 Err:4 http://archive.ubuntu.com/ubuntu focal-backports InRelease
#0 168.5 Temporary failure resolving 'archive.ubuntu.com'
#0 168.5 Reading package lists...
#0 168.5 Building dependency tree...
#0 168.5 Reading state information...
#0 168.5 All packages are up to date.
#0 168.5 W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease Temporary failure resolving 'archive.ubuntu.com'
#0 168.5 W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease Temporary failure resolving 'archive.ubuntu.com'
#0 168.5 W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease Temporary failure resolving 'archive.ubuntu.com'
#0 168.5 W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/focal-security/InRelease Temporary failure resolving 'security.ubuntu.com'
#0 168.5 W: Some index files failed to download. They have been ignored, or old ones used instead.
#0 168.5
#0 168.5 WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
#0 168.5
#0 168.5 E: Unable to locate package wget
Dockerfile:3
2 |
3 | >>> RUN apt update && apt install -y wget && \
4 | >>> wget -q https://packages.microsoft.com/config/ubuntu/20.04/packages-microsoft-prod.deb -O packages-microsoft-prod.deb && \
5 | >>> dpkg -i packages-microsoft-prod.deb && \
6 | >>> rm packages-microsoft-prod.deb && \
7 | >>> apt update && \
8 | >>> apt install -y dotnet-sdk-6.0 && \
9 | >>> apt install -y build-essential && \
10 | >>> apt install -y cmake && \
11 | >>> apt install -y libssl-dev && \
12 | >>> apt install -y libgpiod-dev && \
13 | >>> apt install -y libi2c-dev && \
14 | >>> apt install -y tmux && \
15 | >>> apt install -y systemctl && \
16 | >>> apt install -y git build-essential libjansson-dev libi2c-dev libgpiod-dev libsensors4-dev libz-dev libsystemd-dev
17 |
ERROR: failed to solve: process "/bin/sh -c apt update && apt install -y wget && wget -q https://packages.microsoft.com/config/ubuntu/20.04/packages-microsoft-prod.deb -O packages-microsoft-prod.deb && dpkg -i packages-microsoft-prod.deb && rm packages-microsoft-prod.deb && apt update && apt install -y dotnet-sdk-6.0 && apt install -y build-essential && apt install -y cmake && apt install -y libssl-dev && apt install -y libgpiod-dev && apt install -y libi2c-dev && apt install -y tmux && apt install -y systemctl && apt install -y git build-essential libjansson-dev libi2c-dev libgpiod-dev libsensors4-dev libz-dev libsystemd-dev" did not complete successfully: exit code: 100
What I have tried:
I verified that the docker daemon.json has the correct DNS IPs.
EDIT: Output of getfacl
user::rwx
group::r-x
other::r-x
