$ sudo apt install rabbitmq-server
Reading package lists... Done
Building dependency tree... Done
rabbitmq-server : Depends: erlang-base (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
erlang-base-hipe (>= 1:25.0) but it is not installable or
esl-erlang (>= 1:25.0) but it is not installable
Depends: erlang-crypto (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Depends: erlang-eldap (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Depends: erlang-inets (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Depends: erlang-mnesia (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Depends: erlang-os-mon (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Depends: erlang-parsetools (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Depends: erlang-public-key (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Depends: erlang-runtime-tools (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Depends: erlang-ssl (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Depends: erlang-syntax-tools (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Depends: erlang-tools (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Depends: erlang-xmerl (>= 1:25.0) but 1:24.2.1+dfsg-1ubuntu0.1 is to be installed or
Asked
Active
Viewed 233 times
waltinator
- 37,856
