1.I try to run sudo apt upgrade and also dist upgrade, still cannot upgrade, the package still kept back.
sudo apt-get upgrade mysql-server
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages have unmet dependencies: mysql-common : Conflicts: mysql-server-8.0 but 8.0.33-0ubuntu0.22.04.2 is to be installed mysql-community-client : Conflicts: mysql-server-8.0 but 8.0.33-0ubuntu0.22.04.2 is to be installed mysql-server-8.0 : Depends: mysql-client-8.0 (>= 8.0.33-0ubuntu0.22.04.2) but it is not installable Depends: mysql-server-core-8.0 (= 8.0.33-0ubuntu0.22.04.2) but it is not installable E: Broken packages
2.I read it from ask ubuntu the solutions is to purge and remove mysql-community-client and i get the second error like i paste below, please help.i can't remove or purge mysql-community-client MySQL - Cannot update to 8.0.31 from 8.0.30 at Ubuntu 22.04.1
  1. How can i fix this without losing all mysql database?
     sudo apt purge mysql-community-client
    The following packages have unmet dependencies: dbconfig-mysql : Depends: default-mysql-client but it is not going to be installed or virtual-mysql-client E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Fhazal
