I am trying to play around and understanding ttys. In one terminal emulator window, the output of tty gives me
$ tty
/dev/ttys010
So I figured if I write to this device, the terminal window will show the output. In a second window, when I run
$ echo "test" > /dev/ttys010
The first window shows the word "test" as expect. However, when I run
$ echo "test" | /dev/ttys010
I get no output in the first window. Why is this? I assume its because | redirects stdout to programs while > redirects output to files.
