I have an old server running Ubuntu 18.04.6 LTS, and I suspect that someone tried to install or upgrade to the wrong Ubuntu 20.04 packages, resulting in a broken apt and a so-called "Frankensystem."
I would like to fix this issue without resorting to reinstalling the entire system, especially since the server is located in a remote location. Is it possible to fix the broken packages one by one, and if so, how can I do this?
Here are the errors I encounter:
When running sudo apt update:
$ sudo apt update
Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Get:3 http://archive.ubuntu.com/ubuntu focal-backports InRelease [108 kB]
Get:4 http://archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Fetched 222 kB in 2s (118 kB/s)
Traceback (most recent call last):
  File "/usr/lib/cnf-update-db", line 8, in <module>
    from CommandNotFound.db.creator import DbCreator
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 11, in <module>
    import apt_pkg
ImportError: libapt-pkg.so.6.0: cannot open shared object file: No such file or directory
Reading package lists... Done
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
when running sudo apt --fix-broken install:
$ sudo apt --fix-broken install
Building dependency tree... Done
Correcting dependencies... failed.
 dirmngr : Depends: init-system-helpers (>= 1.52) but 1.51 is installed
 gir1.2-gtk-3.0 : Depends: gir1.2-gdkpixbuf-2.0 (>= 2.40.0) but 2.36.11-2 is installed
                  Depends: gir1.2-pango-1.0 (>= 1.41.0) but 1.40.14-1ubuntu0.1 is installed
                  Depends: libgtk-3-0 (>= 3.24.7) but 3.22.30-1ubuntu4 is installed
 gnupg : Depends: gpgv (>= 2.2.19-3ubuntu2.2) but 2.2.4-1ubuntu1.6 is installed
 gnupg-utils : Depends: libreadline8 (>= 6.0) but it is not installed
 gpg : Depends: libreadline8 (>= 6.0) but it is not installed
 gpg-agent : Depends: init-system-helpers (>= 1.52) but 1.51 is installed
 gpgconf : Depends: libreadline8 (>= 6.0) but it is not installed
 gpgsm : Depends: libreadline8 (>= 6.0) but it is not installed
 hplip : Depends: hplip-data (= 3.20.3+dfsg0-2) but 3.17.10+
when I check /usr/lib/x86_64-linux-gnu I found libapt-pkg.so.5.0 exists and but no libapt-pkg.so.6.0
Also, in /usr/lib/python3/dist-packages I found apt_pkg.cpython-38-x86_64-linux-gnu.so which is strange, because the python3 version is 3.6.9
Regarding backups, I found these files
/var/backups$ ls -l
total 7276
-rw-r--r-- 1 root root    153600 Apr 10 00:08 alternatives.tar.0
-rw-r--r-- 1 root root      9783 Jun 24  2022 alternatives.tar.1.gz
-rw-r--r-- 1 root root      9808 Nov 27  2021 alternatives.tar.2.gz
-rw-r--r-- 1 root root      9421 Mar 27  2021 alternatives.tar.3.gz
-rw-r--r-- 1 root root      6161 Mar 18  2021 alternatives.tar.4.gz
-rw-r--r-- 1 root root      6090 Jan 25  2021 alternatives.tar.5.gz
-rw-r--r-- 1 root root      6061 Nov 28  2020 alternatives.tar.6.gz
-rw-r--r-- 1 root root    154853 Apr  9 23:02 apt.extended_states.0
-rw-r--r-- 1 root root     12962 Apr  9 21:44 apt.extended_states.1.gz
-rw-r--r-- 1 root root     12828 Jul 26  2022 apt.extended_states.2.gz
-rw-r--r-- 1 root root     12821 Jul  4  2022 apt.extended_states.3.gz
-rw-r--r-- 1 root root     12806 Jun 23  2022 apt.extended_states.4.gz
-rw-r--r-- 1 root root     13304 Jun 17  2022 apt.extended_states.5.gz
-rw-r--r-- 1 root root     13269 Nov 26  2021 apt.extended_states.6.gz
-rw-r--r-- 1 root root      4649 Jun 23  2022 dpkg.diversions.0
-rw-r--r-- 1 root root       657 Jun 23  2022 dpkg.diversions.1.gz
-rw-r--r-- 1 root root       657 Jun 23  2022 dpkg.diversions.2.gz
-rw-r--r-- 1 root root       657 Jun 23  2022 dpkg.diversions.3.gz
-rw-r--r-- 1 root root       657 Jun 23  2022 dpkg.diversions.4.gz
-rw-r--r-- 1 root root       657 Jun 23  2022 dpkg.diversions.5.gz
-rw-r--r-- 1 root root       657 Jun 23  2022 dpkg.diversions.6.gz
-rw-r--r-- 1 root root       348 Mar 18  2021 dpkg.statoverride.0
-rw-r--r-- 1 root root       213 Mar 18  2021 dpkg.statoverride.1.gz
-rw-r--r-- 1 root root       213 Mar 18  2021 dpkg.statoverride.2.gz
-rw-r--r-- 1 root root       213 Mar 18  2021 dpkg.statoverride.3.gz
-rw-r--r-- 1 root root       213 Mar 18  2021 dpkg.statoverride.4.gz
-rw-r--r-- 1 root root       213 Mar 18  2021 dpkg.statoverride.5.gz
-rw-r--r-- 1 root root       213 Mar 18  2021 dpkg.statoverride.6.gz
-rw-r--r-- 1 root root   2529012 Jul  3 16:58 dpkg.status.0
-rw-r--r-- 1 root root    708160 Apr 10 00:09 dpkg.status.1.gz
-rw-r--r-- 1 root root    708160 Apr 10 00:09 dpkg.status.2.gz
-rw-r--r-- 1 root root    708160 Apr 10 00:09 dpkg.status.3.gz
-rw-r--r-- 1 root root    708160 Apr 10 00:09 dpkg.status.4.gz
-rw-r--r-- 1 root root    708160 Apr 10 00:09 dpkg.status.5.gz
-rw-r--r-- 1 root root    708160 Apr 10 00:09 dpkg.status.6.gz
-rw------- 1 root root      1336 Apr  9 22:33 group.bak
-rw------- 1 root shadow    1107 Apr  9 22:33 gshadow.bak
-rw------- 1 root root      3518 Apr  9 22:33 passwd.bak
-rw-r--r-- 1 root smmsp    64178 Mar 18  2021 sendmail.cf.bak
-rw-r--r-- 1 root smmsp     4058 Mar 18  2021 sendmail.mc.bak
-rw------- 1 root shadow    2479 Apr  9 22:33 shadow.bak
-rw-r--r-- 1 root smmsp    44618 Mar 18  2021 submit.cf.bak
-rw-r--r-- 1 root smmsp     2375 Mar 18  2021 submit.mc.bak
Or can I use any of these files to restore the system to a working apt?
