To the point
Needles to say that:
Purging hundreds of installed packages at once is a bad idea regardless of the reason for that.
Using APT's option -y to automatically answer yes, is even a worse idea.
You probably know that, but I had to note it ... On to your question:
AFAIK APT can't do that ... APT does more than the basic actions of just attempt to install, remove, purge ... etc. ... It resolves dependencies, avoids and warns about conflicts, substitutes some removed packages ... etc. ... Thus it has to parse/check all passed packages against its cached available packages database before it begins committing any user specified action on them.
Therefore, your best bet in that situation is to pass those packages one at a time to APT using xargs like:
echo "pack1 pack2 pack3" | xargs -n 1 apt purge
or using a shell loop like:
for p in "pack1" "pack2" "pack3"
do
apt purge "$p"
done
or similar solutions.
On the other hand, if using APT is not a must for you, then dpkg should do the job without exiting on such packages "Unable to locate packages" and can be used like so:
dpkg --purge pack1 pack2 pack3
Around the point
Demonstration:
$ apt -s purge -y vlc golang
NOTE: This is only a simulation!
apt needs root privileges for real execution.
Keep also in mind that locking is deactivated,
so don't depend on the relevance to the real current situation!
Reading package lists... Done
Building dependency tree... Done
Package 'golang' is not installed, so not removed
The following packages will be REMOVED:
vlc*
0 to upgrade, 0 to newly install, 1 to remove and 5 not to upgrade.
Purg vlc [3.0.16-1build7]
Notice the three steps before committing the purge action:
These are self explanatory and although the package golang is not installed:
Package 'golang' is not installed, ...
But, APT could locate it in its cached packages list and thus could take a decision regarding it:
... so not removed
and:
vlc*
That is normal and APT will carry on removing the installed package/s
But in case of a package that APT can't locate in its cached packages lists:
$ apt -s purge -y vlc non-locatable-package
E: Unable to locate package non-locatable-package
APT can't take the decision and thus exits after printing an error:
Important notice:
As seen in the demonstration above, APT checks its cached packages lists obtained via the update action and therefore, an up to date packages list/s is vital to correct functionality of APT and doing purge/remove or even install actions with an outdated packages list/s might result in an unexpected result removing unintended packages ... See for example apt-get install unexpectedly removed Firefox ... Therefore, make sure the packages list/s are up to date by running:
sudo apt update
first.
