I'm PXE booting the ISO and using the new Subiquity installer. I've got a working autoinstall setup/config with a working user-data file.
What's not working is that I have an ansible: section that the autoinstall completely ignores. The ansible module is supported in the cloud-init reference but not in the Ubuntu server autoinstall reference.
What I am wondering is if I am being stupid by assuming that the autoinstall options support all of the cloud-init modules?
Ubuntu Server Auto-Install Reference - https://ubuntu.com/server/docs/install/autoinstall-reference Cloud-Init Module Reference - https://cloudinit.readthedocs.io/en/latest/reference/modules.html#
Ken
  • 61
There's actually a difference between autoinstall and cloud-init. I also got mislead. Here's a small hint from the autoinstall documentation: "Note that autoinstall is processed by Subiquity (not cloud-init)". So you can't expect from autoinstall processing cloud-init parameters.
Boris
  • 59
TL;DR: The ansible: stanza should be placed under autoinstall.user-data, which is the user-data section that will be executed in the target system.
Otherwise, if placed in the top level, it will be executed in the ephemeral system (during installation).
Documentation / explanation about the relationship between cloud-init and autoinstall: https://canonical-subiquity.readthedocs-hosted.com/en/latest/explanation/cloudinit-autoinstall-interaction.html#cloudinit-autoinstall-interaction.
aciba
  • 81
