I have working applications communicating over dbus, tried to setup docker some time ago and probably messed up something because my apps can no longer connect...
Right now when I try to run my app which uses qdbus I have
Cannot connect to the D-Bus session bus.
Please check your system settings and try again.
or when I even try to check currently running session bus'es with qdbus I'm getting
qdbus
Could not connect to D-Bus server: org.freedesktop.DBus.Error.FileNotFound: Failed to connect to socket /run/user/1000/bus: No such file or directory
$XDG_RUNTIME_DIR is set to
-bash: /run/user/1000/: Is a directory
$DBUS_SESSION_BUS_ADDRESS
-bash: unix:path=/run/user/1000/bus: No such file or directory
I tried to create bus directory under/run/user/1000 but then I'm getting connection refused
Would someone point what did I mess up
