I am currently on Ubuntu 22.04 LTS.
When I run sudo apt-get upgrade I receive the following error:
 libcrypt1 : Depends: libc6 (>= 2.25) but it is not installed
 libgcc-s1 : Depends: libc6 (>= 2.35) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
When I attempt apt --fix-broken install and also manually installing libc6 I receive the following error:
 /var/cache/apt/archives/libc6_2.35-0ubuntu3.1_amd64.deb
Then I followed the steps I found on this website for that error message:
https://itsfoss.com/dpkg-returned-an-error-code-1/
None of these steps resolved my issue. Is there anyway to fix these broken package dependencies? Thank you in advance for any assistance.
EDIT: Adding the following requested outputs.
sudo apt update:
Hit:1 http://us.archive.ubuntu.com/ubuntu jammy InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu jammy-updates InRelease
Get:3 http://us.archive.ubuntu.com/ubuntu jammy-backports InRelease [108 kB]
Hit:4 http://security.ubuntu.com/ubuntu jammy-security InRelease
Hit:5 https://ppa.launchpadcontent.net/danielrichter2007/grub-customizer/ubuntu jammy InRelease
Fetched 108 kB in 11s (10.2 kB/s)
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
apt policy libcrypt1:
libcrypt1:
  Installed: 1:4.4.27-1
  Candidate: 1:4.4.27-1
  Version table:
 *** 1:4.4.27-1 500
        500 http://us.archive.ubuntu.com/ubuntu jammy/main amd64 Packages
        100 /var/lib/dpkg/status
apt policy libgcc-s1:
libgcc-s1:
  Installed: 12.1.0-2ubuntu1~22.04
  Candidate: 12.1.0-2ubuntu1~22.04
  Version table:
 *** 12.1.0-2ubuntu1~22.04 500
        500 http://us.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
        500 http://security.ubuntu.com/ubuntu jammy-security/main amd64 Packages
     12-20220319-1ubuntu1 500
apt policy libc6:
libc6:
  Installed: (none)
  Candidate: 2.35-0ubuntu3.1
  Version table:
     2.35-0ubuntu3.1 500
     2.35-0ubuntu3 500
dpkg -l libc6:
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name           Version      Architecture Description
in  libc6:amd64    <none>       amd64        (no description available)
sudo apt install libc6:i386:
You might want to run 'apt --fix-broken install' to correct these.
 libc6:i386 : Depends: libgcc-s1:i386 but it is not going to be installed
              Depends: libcrypt1:i386 (>= 1:4.4.10-10ubuntu4) but it is not going to be installed
              Recommends: libidn2-0:i386 (>= 2.0.5~) but it is not going to be installed
              Recommends: libnss-nis:i386 but it is not going to be installed
              Recommends: libnss-nisplus:i386 but it is not going to be installed
 libcrypt1 : Depends: libc6 (>= 2.25) but it is not going to be installed
 libgcc-s1 : Depends: libc6 (>= 2.35) but it is not going to be installed
dpkg -S /lib/x86_64-linux-gnu/libc.so.6:
dpkg-query: warning: files list file for package 'libcrypt1:amd64' missing; assuming package has no files currently installed
dpkg-query: warning: files list file for package 'libgcc-s1:amd64' missing; assuming package has no files currently installed
dpkg-query: no path found matching pattern /lib/x86_64-linux-gun/libc.so.6
My solution ended up being to clean install Ubuntu 23.04. At this point it was much more efficient. I have Windows, Ubuntu, and my data all on separate drives, so nothing important is lost and setting Ubuntu up is fast and easy.
My solution was to add i386 arch to jammy-updates in /etc/apt/sources.list
deb [arch=amd64,i386] http://tn.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
Then run
sudo apt --fix-broken install
and it is fixed.
