I have a Ubuntu Server with Exim4 MTA. Everything is running OK. I must integrate Spam Lists, in Exim4. How can I integrate Spam Lists with Exim4?
One of the Spam List i want to integrate is from Spamhaus.
Seth
  • 59,332
Ok, I just figured out, how it can work.
Edit the file:
vim /etc/exim4/conf.d/main/02_exim4-config_options
Insert the following in bottom of the file:
# Spamhaus RBL zen.spamhaus.org
CHECK_RCPT_IP_DNSBLS = zen.spamhaus.org
Edit the file:
vim  /etc/exim4/conf.d/acl/30_exim4-config_check_rcpt
Search for:
Then change, "warn" to "deny" as shown below:
# Check against classic DNS "black" lists (DNSBLs) which list
# sender IP addresses
.ifdef CHECK_RCPT_IP_DNSBLS
deny
message = X-Warning: $sender_host_address is listed at $dnslist_domain ($dnslist_value: $dnslist_text)
log_message = $sender_host_address is listed at $dnslist_domain ($dnslist_value: $dnslist_text)
dnslists = CHECK_RCPT_IP_DNSBLS
.endif
We must restart Exim:
/etc/init.d/exim4 restart
To test this configuration and see if the PBL blocking is working by sending an email (any email) to: nelson-pbl-test@crynwr.com
The system will answer, to tell if your server is correctly blocking PBL-listed IP addresses or not.
