I was looking to set up a new partition on my hard drive and I accidentally made a typo in the fstab configuration file. To be precise, I addded a partition that was not yet formatted in the partition table and rebooted afterwards.
Now, when I start my machine, the system fails to boot properly and enters emergency mode.This is what appears on my screen
You are in emergency mode. After logging in, type "journalctl -xb" to view system logs, "systemctl reboot" to reboot, "sytemctl default" or "exit" to boot into default mode.
Press Enter for maintenence (or press Control-D to continue):
When I enter my regular user password, the machine won't login to the shell, neither does leaving this field empty work ( as this post would suggest)
I am very new to ubuntu and I have heard that since I didn't set a root password, I assume there is no valid password that can work there
How should I proceed ?
Don't hesitate to ask for other informations
EDIT : I made a fresh install of ubuntu server, and I mounted my old filesystem at /mnt, and for some reason I didn't have to edit fstab afterwards, the system just booted fine. ( see the picture below)
Unbuntu install menu
You need any linux live CD or image.
Boot up the live cd, then mount the filesystem which contains the /etc/fstab file into maybe the /mnt then just edit the fstab there.
Then the OS should boot up correctly.
If you need to kick the root password, just remove the hash from shadow for root.
Some live CD-s has tools for change root password too.
HBtools
  • 23
