I am using Ubuntu 23.04 and while upgrading i get some errors i don't understand.
sudo apt upgrade -y
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages will be REMOVED:
  linux-image-5.19.0-40-generic
The following packages have been kept back:
  gdm3 gir1.2-gdm-1.0 gir1.2-gtk-4.0 libcupsfilters2 libcupsfilters2-common
  libgdm1 libgtk-4-1 libgtk-4-bin libgtk-4-common libgtk-4-media-gstreamer
  libppd2 libppd2-common qemu-block-extra qemu-system-common qemu-system-data
  qemu-system-gui qemu-system-x86 qemu-utils
0 upgraded, 0 newly installed, 1 to remove and 18 not upgraded.
2 not fully installed or removed.
After this operation, 12.2 MB disk space will be freed.
(Reading database ... 277827 files and directories currently installed.)
Removing linux-image-5.19.0-40-generic (5.19.0-40.41) ...
/etc/kernel/postrm.d/initramfs-tools:
update-initramfs: Deleting /boot/initrd.img-5.19.0-40-generic
/etc/kernel/postrm.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-6.2.0-23-generic
Found initrd image: /boot/initrd.img-6.2.0-23-generic
Found linux image: /boot/vmlinuz-6.2.0-20-generic
Found initrd image: /boot/initrd.img-6.2.0-20-generic
Found memtest86+ 64bit EFI image: /boot/memtest86+x64.efi
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings ...
error: out of memory.
error: syntax error.
error: Incorrect command.
Syntax error at line 267
Syntax errors are detected in generated GRUB config file.
Ensure that there are no errors in /etc/default/grub
and /etc/grub.d/* files or please file a bug report with
/boot/grub/grub.cfg.new file attached.
run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 1
dpkg: error processing package linux-image-5.19.0-40-generic (--remove):
 installed linux-image-5.19.0-40-generic package post-removal script subprocess
returned error exit status 1
dpkg: too many errors, stopping
Processing was halted because there were too many errors.
what is the problem here
os-prober has been disabled, you have to edit /etc/default/grub to add: GRUB_DISABLE_OS_PROBER=false and run sudo update-grub
related
Talaat Etman
  • 1,340
