On Ubuntu 22.04 server
I am trying to compile eapol_test from wpa_supplicant-2.10 as found on
make eapol_test
(Following "THE FREERADIUS IMPLEMENTATION GUIDE" (2014 network radius sarl) chapter 6 -EAP authentication, Pg 46,47) https://networkradius.com/doc/FreeRADIUS-Implementation-Ch6.pdf
I've set
CONFIG_EAPOL_TEST=y
in the .config
I get plenty of "deprecated: Since OpenSSL 3.0" errors. (on Ubuntu 22.04.2 LTS) The full output is below.
Thanks in advance for your advice,
CC config.c
CC notify.c
CC bss.c
CC eap_register.c
CC ../src/utils/common.c
CC ../src/utils/config.c
CC ../src/utils/wpa_debug.c
CC ../src/utils/wpabuf.c
CC ../src/utils/bitfield.c
CC ../src/utils/ip_addr.c
CC ../src/utils/crc32.c
CC op_classes.c
CC rrm.c
CC twt.c
CC robust_av.c
CC wmm_ac.c
CC ../src/utils/os_unix.c
CC ../src/utils/eloop.c
CC config_file.c
CC ../src/rsn_supp/wpa_ft.c
CC ../src/common/sae.c
CC ../src/common/dpp.c
CC ../src/common/dpp_auth.c
CC ../src/common/dpp_backup.c
CC ../src/common/dpp_crypto.c
CC ../src/common/dpp_pkex.c
CC ../src/common/dpp_reconfig.c
CC ../src/common/dpp_tcp.c
CC dpp_supplicant.c
CC ../src/rsn_supp/tdls.c
CC ../src/rsn_supp/wpa.c
CC ../src/rsn_supp/preauth.c
CC ../src/rsn_supp/pmksa_cache.c
CC ../src/rsn_supp/wpa_ie.c
CC ../src/common/wpa_common.c
CC ibss_rsn.c
CC p2p_supplicant.c
CC p2p_supplicant_sd.c
CC ../src/p2p/p2p.c
CC ../src/p2p/p2p_utils.c
CC ../src/p2p/p2p_parse.c
CC ../src/p2p/p2p_build.c
CC ../src/p2p/p2p_go_neg.c
CC ../src/p2p/p2p_sd.c
CC ../src/p2p/p2p_pd.c
CC ../src/p2p/p2p_invitation.c
CC ../src/p2p/p2p_dev_disc.c
CC ../src/p2p/p2p_group.c
CC ../src/ap/p2p_hostapd.c
CC wifi_display.c
CC hs20_supplicant.c
CC interworking.c
CC ../src/eap_peer/eap_tls.c
CC ../src/eap_peer/eap_peap.c
CC ../src/eap_common/eap_peap_common.c
CC ../src/eap_peer/eap_ttls.c
CC ../src/eap_peer/eap_md5.c
CC ../src/eap_peer/eap_mschapv2.c
CC ../src/eap_peer/mschapv2.c
CC ../src/eap_peer/eap_gtc.c
CC ../src/eap_peer/eap_otp.c
CC ../src/eap_peer/eap_leap.c
CC ../src/eap_peer/eap_fast.c
CC ../src/eap_peer/eap_fast_pac.c
CC ../src/eap_common/eap_fast_common.c
CC ../src/eap_peer/eap_pax.c
CC ../src/eap_common/eap_pax_common.c
CC ../src/eap_peer/eap_sake.c
CC ../src/eap_common/eap_sake_common.c
CC ../src/eap_peer/eap_gpsk.c
CC ../src/eap_common/eap_gpsk_common.c
CC ../src/eap_peer/eap_pwd.c
CC ../src/eap_common/eap_pwd_common.c
CC wps_supplicant.c
CC ../src/utils/uuid.c
CC ../src/eap_peer/eap_wsc.c
CC ../src/eap_common/eap_wsc_common.c
CC ../src/wps/wps.c
CC ../src/wps/wps_common.c
CC ../src/wps/wps_attr_parse.c
CC ../src/wps/wps_attr_build.c
CC ../src/wps/wps_attr_process.c
CC ../src/wps/wps_dev_attr.c
CC ../src/wps/wps_enrollee.c
CC ../src/wps/wps_registrar.c
CC ../src/eap_peer/eap_ikev2.c
CC ../src/eap_peer/ikev2.c
CC ../src/eap_common/eap_ikev2_common.c
CC ../src/eap_common/ikev2_common.c
CC ../src/eap_peer/eap_tnc.c
CC ../src/eap_peer/tncc.c
CC wpas_kay.c
CC ../src/pae/ieee802_1x_cp.c
CC ../src/pae/ieee802_1x_kay.c
CC ../src/pae/ieee802_1x_key.c
CC ../src/pae/ieee802_1x_secy_ops.c
CC ../src/ap/wpa_auth_kay.c
CC ../src/eapol_supp/eapol_supp_sm.c
CC ../src/eap_peer/eap.c
CC ../src/eap_peer/eap_methods.c
CC ap.c
CC ../src/ap/hostapd.c
CC ../src/ap/wpa_auth_glue.c
CC ../src/ap/utils.c
CC ../src/ap/authsrv.c
CC ../src/ap/ap_config.c
CC ../src/ap/sta_info.c
CC ../src/ap/tkip_countermeasures.c
CC ../src/ap/ap_mlme.c
CC ../src/ap/ieee802_1x.c
CC ../src/eapol_auth/eapol_auth_sm.c
CC ../src/ap/ieee802_11_auth.c
CC ../src/ap/ieee802_11_shared.c
CC ../src/ap/drv_callbacks.c
CC ../src/ap/ap_drv_ops.c
CC ../src/ap/beacon.c
CC ../src/ap/bss_load.c
CC ../src/ap/eap_user_db.c
CC ../src/ap/neighbor_db.c
CC ../src/ap/rrm.c
CC ../src/ap/ieee802_11_ht.c
CC ../src/ap/ieee802_11_vht.c
CC ../src/ap/ctrl_iface_ap.c
CC ../src/eap_server/eap_server.c
CC ../src/eap_server/eap_server_identity.c
CC ../src/eap_server/eap_server_methods.c
CC ../src/ap/wmm.c
CC ../src/ap/ap_list.c
CC ../src/ap/ieee802_11.c
CC ../src/ap/hw_features.c
CC ../src/ap/dfs.c
CC ../src/ap/wps_hostapd.c
CC ../src/eap_server/eap_server_wsc.c
CC ../src/ap/dpp_hostapd.c
CC ../src/ap/gas_query_ap.c
CC ../src/ap/gas_serv.c
CC ../src/ap/hs20.c
CC ../src/ap/wpa_auth.c
CC ../src/ap/wpa_auth_ie.c
CC ../src/ap/pmksa_cache_auth.c
CC ../src/common/dragonfly.c
CC ../src/crypto/ms_funcs.c
CC ../src/eap_common/chap.c
CC ../src/eap_peer/eap_tls_common.c
../src/crypto/tls_openssl.c: In function ‘tls_engine_load_dynamic_generic’:
../src/crypto/tls_openssl.c:799:9: error: ‘ENGINE_by_id’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
799 | engine = ENGINE_by_id(id);
In file included from ../src/crypto/tls_openssl.c:25:
/usr/include/openssl/engine.h:336:31: note: declared here
336 | OSSL_DEPRECATEDIN_3_0 ENGINE *ENGINE_by_id(const char *id);
../src/crypto/tls_openssl.c:814:9: error: ‘ENGINE_by_id’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
814 | engine = ENGINE_by_id(dynamic_id);
../src/crypto/tls_openssl.c:825:17: error: ‘ENGINE_ctrl_cmd_string’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
825 | if (ENGINE_ctrl_cmd_string(engine, pre[0], pre[1], 0) == 0) {
/usr/include/openssl/engine.h:479:5: note: declared here
479 | int ENGINE_ctrl_cmd_string(ENGINE *e, const char *cmd_name, const char *arg,
../src/crypto/tls_openssl.c:829:25: error: ‘ENGINE_free’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
829 | ENGINE_free(engine);
/usr/include/openssl/engine.h:493:27: note: declared here
493 | OSSL_DEPRECATEDIN_3_0 int ENGINE_free(ENGINE *e);
../src/crypto/tls_openssl.c:839:9: error: ‘ENGINE_free’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
839 | ENGINE_free(engine);
../src/crypto/tls_openssl.c:841:9: error: ‘ENGINE_by_id’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
841 | engine = ENGINE_by_id(id);
../src/crypto/tls_openssl.c:850:17: error: ‘ENGINE_ctrl_cmd_string’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
850 | if (ENGINE_ctrl_cmd_string(engine, post[0], post[1], 0) == 0) {
../src/crypto/tls_openssl.c:854:25: error: ‘ENGINE_remove’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
854 | ENGINE_remove(engine);
/usr/include/openssl/engine.h:332:27: note: declared here
332 | OSSL_DEPRECATEDIN_3_0 int ENGINE_remove(ENGINE *e);
../src/crypto/tls_openssl.c:855:25: error: ‘ENGINE_free’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
855 | ENGINE_free(engine);
../src/crypto/tls_openssl.c:860:9: error: ‘ENGINE_free’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
860 | ENGINE_free(engine);
../src/crypto/tls_openssl.c: In function ‘tls_init’:
../src/crypto/tls_openssl.c:1089:9: error: ‘ENGINE_load_builtin_engines’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
1089 | ENGINE_load_builtin_engines();
/usr/include/openssl/engine.h:358:28: note: declared here
358 | OSSL_DEPRECATEDIN_3_0 void ENGINE_load_builtin_engines(void);
../src/crypto/tls_openssl.c: In function ‘tls_engine_init’:
../src/crypto/tls_openssl.c:1213:9: error: ‘ENGINE_by_id’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
1213 | conn->engine = ENGINE_by_id(engine_id);
../src/crypto/tls_openssl.c:1219:9: error: ‘ENGINE_init’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
1219 | if (ENGINE_init(conn->engine) != 1) {
/usr/include/openssl/engine.h:620:27: note: declared here
620 | OSSL_DEPRECATEDIN_3_0 int ENGINE_init(ENGINE *e);
../src/crypto/tls_openssl.c:1228:9: error: ‘ENGINE_ctrl_cmd_string’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
1228 | if (pin && ENGINE_ctrl_cmd_string(conn->engine, "PIN", pin, 0) == 0) {
../src/crypto/tls_openssl.c:1245:17: error: ‘ENGINE_load_private_key’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
1245 | conn->private_key = ENGINE_load_private_key(conn->engine,
/usr/include/openssl/engine.h:638:11: note: declared here
638 | EVP_PKEY *ENGINE_load_private_key(ENGINE *e, const char *key_id,
../src/crypto/tls_openssl.c:1268:17: error: ‘ENGINE_ctrl’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
1268 | if (!ENGINE_ctrl(conn->engine, ENGINE_CTRL_GET_CMD_FROM_NAME,
/usr/include/openssl/engine.h:429:27: note: declared here
429 | OSSL_DEPRECATEDIN_3_0 int ENGINE_ctrl(ENGINE *e, int cmd, long i, void *p,
../src/crypto/tls_openssl.c:1281:17: error: ‘ENGINE_free’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
1281 | ENGINE_free(conn->engine);
../src/crypto/tls_openssl.c: In function ‘tls_engine_deinit’:
../src/crypto/tls_openssl.c:1307:17: error: ‘ENGINE_finish’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
1307 | ENGINE_finish(conn->engine);
/usr/include/openssl/engine.h:628:27: note: declared here
628 | OSSL_DEPRECATEDIN_3_0 int ENGINE_finish(ENGINE *e);
../src/crypto/tls_openssl.c: In function ‘tls_engine_get_cert’:
../src/crypto/tls_openssl.c:3605:9: error: ‘ENGINE_ctrl_cmd’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
3605 | if (!ENGINE_ctrl_cmd(conn->engine, "LOAD_CERT_CTRL",
/usr/include/openssl/engine.h:450:27: note: declared here
450 | OSSL_DEPRECATEDIN_3_0 int ENGINE_ctrl_cmd(ENGINE *e, const char *cmd_name,
../src/crypto/tls_openssl.c: In function ‘tls_connection_private_key’:
../src/crypto/tls_openssl.c:3827:17: error: ‘SSL_use_RSAPrivateKey_ASN1’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
3827 | if (SSL_use_RSAPrivateKey_ASN1(conn->ssl,
In file included from ../src/crypto/tls_openssl.c:19:
/usr/include/openssl/ssl.h:1652:12: note: declared here
1652 | __owur int SSL_use_RSAPrivateKey_ASN1(SSL *ssl,
../src/crypto/tls_openssl.c: In function ‘tls_connection_dh’:
../src/crypto/tls_openssl.c:3966:9: error: ‘PEM_read_bio_DHparams’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
3966 | dh = PEM_read_bio_DHparams(bio, NULL, NULL, NULL);
In file included from /usr/include/openssl/ssl.h:36,
/usr/include/openssl/pem.h:469:1: note: declared here
469 | DECLARE_PEM_rw_attr(OSSL_DEPRECATEDIN_3_0, DHparams, DH)
../src/crypto/tls_openssl.c:3977:17: error: ‘PEM_read_bio_DSAparams’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
3977 | dsa = PEM_read_bio_DSAparams(bio, NULL, NULL, NULL);
/usr/include/openssl/pem.h:455:1: note: declared here
455 | DECLARE_PEM_rw_attr(OSSL_DEPRECATEDIN_3_0, DSAparams, DSA)
../src/crypto/tls_openssl.c:3987:17: error: ‘DSA_dup_DH’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
3987 | dh = DSA_dup_DH(dsa);
In file included from /usr/include/openssl/x509.h:37,
from /usr/include/openssl/ssl.h:31,
/usr/include/openssl/dsa.h:198:27: note: declared here
198 | OSSL_DEPRECATEDIN_3_0 DH *DSA_dup_DH(const DSA *r);
../src/crypto/tls_openssl.c:3988:17: error: ‘DSA_free’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
3988 | DSA_free(dsa);
/usr/include/openssl/dsa.h:127:28: note: declared here
127 | OSSL_DEPRECATEDIN_3_0 void DSA_free(DSA *r);
../src/crypto/tls_openssl.c:4007:17: error: ‘DH_free’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
4007 | DH_free(dh);
In file included from /usr/include/openssl/dsa.h:51,
/usr/include/openssl/dh.h:200:28: note: declared here
200 | OSSL_DEPRECATEDIN_3_0 void DH_free(DH *dh);
../src/crypto/tls_openssl.c:4010:9: error: ‘DH_free’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
4010 | DH_free(dh);
../src/crypto/tls_openssl.c: In function ‘tls_global_dh’:
../src/crypto/tls_openssl.c:4041:9: error: ‘PEM_read_bio_DHparams’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
4041 | dh = PEM_read_bio_DHparams(bio, NULL, NULL, NULL);
../src/crypto/tls_openssl.c:4052:17: error: ‘PEM_read_bio_DSAparams’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
4052 | dsa = PEM_read_bio_DSAparams(bio, NULL, NULL, NULL);
../src/crypto/tls_openssl.c:4062:17: error: ‘DSA_dup_DH’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
4062 | dh = DSA_dup_DH(dsa);
../src/crypto/tls_openssl.c:4063:17: error: ‘DSA_free’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
4063 | DSA_free(dsa);
../src/crypto/tls_openssl.c:4082:17: error: ‘DH_free’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
4082 | DH_free(dh);
../src/crypto/tls_openssl.c:4085:9: error: ‘DH_free’ is deprecated: Since OpenSSL 3.0 [-Werror=deprecated-declarations]
4085 | DH_free(dh);
cc1: all warnings being treated as errors
make: *** [../src/build.rules:86: /root/radiusconfig/wpa_supplicant-2.10/build/wpa_supplicant/src/crypto/tls_openssl.o] Error 1
originally posted on
"freeradius-users" <freeradius-users@lists.freeradius.org> and
"hostap" <hostap@lists.infradead.org>
