48
I want to do one way synchronization.
I am having Folder A on my computer which is constantly updated with content.
Another Folder B is used for backup purpose which is on external HDD.
Now what I expect is that whatever extra which is present in folder A should go to folder B. However something which is present in B and NOT in A ""shall NOT be copied to A"".
In a nutshell, the backup folder may copy everything from the source folder, however nothing should be copied form backup folder to the source.
Braiam
  • 69,112
BhaveshDiwan
  • 11,506
  • 35
  • 46
9 Answers9
64
Sounds like a perfect task for rsync
sudo rsync -az /path_to/A /path_to/B
-a archive mode (implies recursive, copy symlinks as symlinks, preserve owner, modification times, group, owner, special and device files)
-z compresses the data
If you wish to remove files deleted in A from files in B, use the --delete option
For additional information see:
https://help.ubuntu.com/community/rsync
You can run rsync from cron
sudo crontab -e
Add in an hourly task
@hourly rsync /path_to/A /path_to/B
https://help.ubuntu.com/community/CronHowto
Byte Commander
  • 110,243
Panther
  • 104,528
15
I'd suggest using rsync for this purpose. Rsync is extremely fast, stable, and versatile. There's a good introduction at http://help.ubuntu.com/community/rsync
If you wish, there is an optional graphic front end: grsync
 sudo rsync -azv --exclude 'dir1' /home/path/folderA/ /home/path/folderB
The command above will copy from folderA to folderB excluding dir1. The flags are
-a preserves time stamps
-z is to enable compression
-v verbose
There are many more options available.
JIm
  • 521
I always found Unison to be very helpful. It has a text based or GUI based interface, and quite a few different options to tweak it to what you want (with a little fiddling). It takes quite a bit of time to do the first sync, but after that it's brilliant. You can make it sync one-way, as you want, but it will pretty much get that automatically. It can also delete from the backup or not as you choose.
You also may find issues with permissions which are supported in the ubuntu file format, but maybe not in the external hard drive (depending whether the external hard drive is going to be used in a windows machine, this may be a good thing), so you'll want to sync without the permissions potentially.
Anyway, the nice thing is that with the tutorial it's relatively straightforward to set it up once, and thereafter it's a GUI interface whenever you want to do it.
Here's some info about it: http://www.ubuntugeek.com/unison-file-synchronization-tool.html
And here's the tutorial: http://www.cis.upenn.edu/~bcpierce/unison/download/releases/stable/unison-manual.html#tutorial
rsync -avPr --ignore-existing /home/username/Research/ /path/to/other/folder/on/hdd/
This will sync and copy only that data that doesn't exist in the /other/folder/on/hdd/
dearN
  • 2,209
I agree with the other answers, you can use in rsync in Terminal or the interfaces Grsync, luckyBackup, Conduit or the famous Unison.
Another great app is Krusader (a Twin-Panel File Manager for KDE), in the Tools menu you can find "Syncronize Directories", is very useful.
In last instance you can install Wine and install another great twin-pane file manager like Total Commander.
Anyway you have plenty of options and all of them are present in the Ubuntu Software Center.
I would recommend Conduit for simple synchronization. It's available the software system. It does exactly what you are looking for
jasonwert
  • 375
There is a quite handy shell tool called rsnapshot - http://www.rsnapshot.org/ - filesystem snapshot utility for making backups of local and remote systems. that uses rsync and hard links which makes it possible to keep multiple, full file system backups instantly available. Just do sudo apt-get install rsnapshot and check info rsnapshot
If you want a graphical interface on a system that is highly configurable, give FreeFileSync a try. See, for example: http://linuxnorth.wordpress.com/2011/11/29/file-and-folder-synchronization/ In particular, you want the "Update" option for synchronization that will "Copy new or updated files to right folder", i.e. copy from the left folder to the right folder in a two-window display.
CentaurusA
  • 2,692
You can sync files inside two direcotries by:
rsync -rv /path/to/directory1/ /path/to/directory2
Doing rsync -rv /path/to/directory1 /path/to/directory2 will create directory1 inside directory2, like this /path/to/directory2/directory1/[files]
You can dry run using -n switch, like this rsync -rnv /path/to/directory1/ /path/to/directory2
Reference: https://www.digitalocean.com/community/tutorials/how-to-use-rsync-to-sync-local-and-remote-directories-on-a-vps
