When I am on the GUI of my VM and I want to change the network connection profile, I can do so as user "vm" via the command below:
vm@ubuntu1804:~$ nmcli con up DYNAMIC
But when I SSH to this box as user VM, and try to run that same command as the same user it says:
Error: Connection activation failed: Not authorized to control networking.
I assumed this was a permissions issue, and verified via the command below
# permissions when on the GUI
vm@ubuntu1804:~$ nmcli general permissions
PERMISSION                                                        VALUE
org.freedesktop.NetworkManager.enable-disable-network             yes
org.freedesktop.NetworkManager.enable-disable-wifi                yes
org.freedesktop.NetworkManager.enable-disable-wwan                yes
org.freedesktop.NetworkManager.enable-disable-wimax               yes
org.freedesktop.NetworkManager.sleep-wake                         no
org.freedesktop.NetworkManager.network-control                    yes
org.freedesktop.NetworkManager.wifi.share.protected               yes
org.freedesktop.NetworkManager.wifi.share.open                    yes
org.freedesktop.NetworkManager.settings.modify.system             yes
org.freedesktop.NetworkManager.settings.modify.own                yes
org.freedesktop.NetworkManager.settings.modify.hostname           auth
org.freedesktop.NetworkManager.settings.modify.global-dns         auth
org.freedesktop.NetworkManager.reload                             auth
org.freedesktop.NetworkManager.checkpoint-rollback                auth
org.freedesktop.NetworkManager.enable-disable-statistics          yes
org.freedesktop.NetworkManager.enable-disable-connectivity-check  yes
permissions when SSH'ing
vm@ubuntu1804:~$ nmcli general permissions PERMISSION VALUE org.freedesktop.NetworkManager.enable-disable-network no
org.freedesktop.NetworkManager.enable-disable-wifi no
org.freedesktop.NetworkManager.enable-disable-wwan no
org.freedesktop.NetworkManager.enable-disable-wimax no
org.freedesktop.NetworkManager.network-control auth
org.freedesktop.NetworkManager.wifi.share.protected no
org.freedesktop.NetworkManager.wifi.share.open no
org.freedesktop.NetworkManager.settings.modify.system no
org.freedesktop.NetworkManager.settings.modify.own auth
org.freedesktop.NetworkManager.enable-disable-statistics no
org.freedesktop.NetworkManager.enable-disable-connectivity-check no
The question is, how do I change it? I tried via the answer in this post Not authorized to control networking but this does not work.
Please note, I am NOT looking for someone to answer my question with "just use sudo".
john smith
  • 3,161
Ok I figured it out, but I'll share. Before I do, I want to add a "caution" because what I'm doing probably isn't a good idea for security reasons (I see this because I have done a bunch of ethical hacking against VM's, and can see the logic behind the setup). The logic behind this default setup where you can't change the network settings by default without sudo, prevents someone who managed to gain access to your system, say as user "www-data" if they exploited your web-front end, and then escalated to the user "vm", they would by default be able to remotely control your networking since I'm changing the system level permissions for the NetworkManager application to grant remote (ssh) access to fully control the networking on the box. It's going to be best if you just use sudo and elevate to change network settings remotely.
In any case, it seems that the permissions are bound to the system rather than specifically to network manager. So the "polkit - Authorization Framework" is the system level tool that grants access to privileged applications FROM an unprivileged "by default" app such as Network Manager. As such I need to create a .pkla file to adjust that authorization (I found this from the ubuntu man pages, specifically: https://manpages.ubuntu.com/manpages/trusty/man8/pklocalauthority.8.html ). So I've stated below, anyone in the sudo group can just change the network settings (i.e. without elevating to sudo, you just need to be part of the sudo group). As such, I verify the permissions changed at the end, and executed my nmcli command to change the profile, and it worked.
root@ubuntu1804:/home/vm# cat /etc/polkit-1/localauthority/50-local.d/test.pkla
[ssh to modify] Identity=unix-group:sudo Action=org.freedesktop.NetworkManager.settings.modify.system ResultAny=yes ResultInactive=yes ResultActive=yes
[ssh to enable and disable network] Identity=unix-group:sudo Action=org.freedesktop.NetworkManager.enable-disable-network ResultAny=yes ResultInactive=yes ResultActive=yes
[ssh to control the networking] Identity=unix-group:sudo Action=org.freedesktop.NetworkManager.network-control ResultAny=yes ResultInactive=yes ResultActive=yes root@ubuntu1804:/home/vm# systemctl restart polkit root@ubuntu1804:/home/vm# exit exit
As you can see the 3 "actions" we defined earlier are now yes to "yes".
PERMISSION                                                        VALUE
Connection successfully activated (D-Bus active path: /org/freedesktop/NetworkManager/ActiveConnection/12)
After this was in place, I am now able to execute the following command as the vm user via ssh:
john smith
  • 3,161
To get the "john smith Jun 10, 2023" answer to work in Ubuntu 24.04.2 LTS, you must also have the polkitd-pkla package installed: sudo apt install polkitd-pkla
Otherwise the pkla file will be silently ignored.
jsiegel5
