I seem to have two separate software centers, one called Ubuntu Software (orange icon), and one called software (multi-color icon). Neither one loads properly and I have tried sudo apt update, purge, refresh, reinstall, to name a few. Nothing has worked and I get the following error; "libdvd-pkg: apt-get check failed, you may have broken packages. Aborting...." The explore and installed tabs either show nothing at all or the categories don't work. Any help would be greatly appreciated!
- 24,696
- 41
The orange icon, Ubuntu Software (confusingly "snapstore" in the software apps), is the one distributed with Ubuntu, the other is Gnome Software, which you must have installed and upon which Ubuntu Software is itself based. I have both and I think the reason was to enable flatpacks through an extension. One problem I have is that if my wired network is not switched on before the desktop is loaded both programmes will launch but the software catalogues won't load, and it is impossible to update the system. The solution is to ensure everything is on at boot time or restart the desktop by logging out then back in again.
Oh and I eventually deleted snapstore because I was getting the same notification for updated software at every boot up re: How can I dismiss "Software Updates Installed" notification?
- 439
I tried sudo snap-store --quit, restarted snap-store, still blank categories, but then I left the keyboard for a bit, when I returned the selected category was loaded!
A bit of testing revealed that a category can take up to a 45 seconds to load, the next load of the category takes a few seconds.
I'm guessing that when ubuntu software says the catalogue is being downloaded, it's only downloading urls.
Got the same result with gnome-software.
