I installed the icaclient (it's a client for Citrix) a while back. I don't exactly remember what I did to get it working but it was enervating. I had to install some old packages not even avaiable for ubuntu (12.04) and in the end I used some stuff from old rpms.
Anyway the client is more or less working now but I always get a dpkg error when installing or updating something. The (translated) error message is something like:
dpkg: Error while processing icaclient:i386 (--configure): subprocess installed post-installation-script return errorcode 2
I just want to tell dpkg to ignore this or remove this post-install-script but I don't know how.
Thanks!
Serge Stroobandt
  • 5,719
  • 54
  • 59
Just install version 12.0 instead of 12.1. It is (still) available on Citrix site (http://www.citrix.com/site/SS/downloads/details.asp?downloadId=2316611&productId=1689163) and works just fine.
Or you can extract the package:
dpkg -x icaclient_12.1.0_amd64.deb /some/folder
mkdir /some/folder/DEBIAN
dpkg -e icaclient_12.1.0_amd64.deb /some/folder/DEBIAN
vi /some/folder/DEBIAN/postinst
In line 2648, change the text between double quotes ("i[0-9]86") for "[0-9,x]86" an then run the following:
dpkg -b /some/folder
It will correct the bug in the postinst script that tries to figure out the architecture of your processor. The 'dpkg -b /some/folder' will then recompile (build) the package. All you need now is to install the recompiled package, which will be named after the folder you used to extract it. I just don't know why Citrix haven't done it yet, for it is a relatively old bug, and with a very simple solution.
If you are not interested in doing the dirty job, just download the version I corrected from https://dl.dropbox.com/u/3207848/icaclient_12.1.0_amd64.deb.
Hope I helped!
Worked for me as well, but I used the 32bit client on my 64bit system.
icaclient-12.1.0_i386.deb
Procedure is the same.
Jeroen
First, please try the following in terminal:
sudo aptitude update
sudo aptitude -f install
If it does not work, then you may want to try:
sudo dpkg --force all --remove
If these are not helping you than I have bad news. There is no way to skip post-install scripts. The official Debian policy is to edit the script to return a non-terminal error, or fix the script.
Frantique
  • 8,673
