I just did a fresh install of Ubuntu desktop for a Plex server I am building, and I had to manually format/partition the two 4TB HDD's I installed. After using the command sudo mkfs.ext4 /dev/sdc (and the same for the other drive name), it mounted both volumes and they show up in the navigation/status bar. I took ownership of them and I can create directories and such as planned.
The only problem is that navigating to them via the CLI is insane because the default name is like (for example) 69b547f6-78e5-4f16-b217-a82a8e106ad2
How can I change this volume name (mount point?) to something simpler for easier navigation?
