I've upgraded my motherboard from an "MSI B450 Tomahawk Max" to an "MSI Mag X570S Torpedo Max". I did not reinstall Ubuntu and initially, on the first boot, everything seemed to be working fine.
From the second restart onwards, my wired internet has slowed to a crawl. It seems there is a long delay when initially trying to create connections, but once the connection has been made, the speed is reasonable.
For example, I am able to download packages using apt-get and using tools like wget and curl work reasonably well. However, I can't install snaps though, they always fail with "unexpected HTTP status code 408 via POST to 'https://api.snapcraft.io/v2/snaps/refresh". Both Firefox and Chrome take a very long time to load everything. We are talking multiple minutes with several refreshes just to bring up the google home page. I can see in the network panel that many resources are just failing to load because it is taking so long to connect and by refreshing, I am serving up the successful ones from a local cache allowing more connections to succeed next time. Once they do connect, they download quite fast.
I have tried running speedtest-cli and regularly get "Cannot retrieve speedtest configuration ERROR: The read operation timed out". When it does manage to do so, the download speeds measured vary wildly and are sometimes terrible and sometimes okay. I have a ~100MB connection and the fastest I've measured is 103.81MB but it will often measure 80, 60 and even as low as 2MB, quite often.
I have tried the following with no change in behavior:
  • Running an Ubuntu live USB.
  • Downgrading from r8169 to r8168.
  • Switching to a different Ethernet port (the motherboard has 2: 1GB and 2.5GB)
  • Setting network.dns.disableIPv6 to true in Firefox.
  • Switching ethernet cables
  • Switching back to the original motherboard
Update Fixed it. It was my router. See my answer.
This turned out to be a case of unfortunate timing and the motherboard upgrade was completely irrelevant.
I tried the same Ethernet cable with another computer and found the exact same networking issue. All other devices in my house were working (both wired and wireless) so I didn't suspect my router but restarting my router fixed the issue.
Sigh... what a waste of time!
I had similar problem. Answer posted here helped me: https://askubuntu.com/a/1396350/1700811
What's is saying you need to update your realtek driver to dkms one by wrtiting into console:
sudo apt update
sudo apt install r8168-dkms
sudo echo "blacklist r8169"  > /etc/modprobe.d/blacklist-r8169.conf
reboot
I need to notice that command:
casted "access denied" error, but it still repaired my ethernet speed.
Piotr
