I'm new to the autoinstall process, where I am finding documentation difficult to follow; however, most of the docs refer to using a virtual machine (qemu) which we are not. On the Autoinstall Quickstart page, it has:
kvm -no-reboot -m 2048
But I'm not seeing other examples that shows the proper command sequence to boot from a kernel prompt (ie: from a ISO where you edit the grub boot). I don't believe I need to assemble an ISO for this use case. We're ultimately going to be putting this into Foreman and we have a couple different system layouts we use.
I've also seen other reference suggesting that your autoinstall file itself has to be named user-data or meta-data (ie: if you're pulling from HTTP).
I've tried doing these and they have failed.
linux /casper/vmlinuz autoinstall ip=DHCP ds=nocloud-net;s=http://our-server/path/to/autoinstall.yaml ---
I renamed autoinstall.yaml to "user-data" no luck. I don't see why the file needs a specific name. Some examples suggest you "need" to escape the semicolon, others not; some suggest you don't need the semicolon. It's been that bizarre.
DHCP worked fine.
I'm looking for some useful, real-world examples of how to properly work with this.
EDIT: I do see reference at :
But even in that article, people seem to be uncertain about what actually works and what does not. For example, some are including ' quotes in the command sequence:
linux /casper/vmlinuz autoinstall quiet ds='nocloud;s=/cdrom/' ---
Which is it? I see multiple concerns/complaints about the official documentation being rather vague or silent on this.
For automation under a system like Foreman, does this mean I will need to create a custom ISO with the autoinstall (user-data) content for each type of system I want to deploy?
