I'm trying to install librespot to use along with spotify-qt, which needs cargo to run, but every time I run sudo apt install cargo I get the following problem:
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may
mean that you have requested an impossible situation or if you are
using the unstable distribution that some required packages have not
yet been created or been moved out of Incoming.
rustc : Depends: libc-dev
And then I tried to use sudo apt install libc-dev but got this error:
Note, selecting 'libc6-dev' instead of 'libc-dev'
The following packages have unmet dependencies: libc6-dev : Depends:
libc6 (= 2.35-0ubuntu3) but 2.35-0ubuntu3.1 is to be installed
I'm new to Ubuntu/Linux and I'm still getting used to it.
