I am trying to give you all the info.. I am quite new on all these things...
Last week I received this while I was trying to install a package on R:
    R error: Installation paths not writable, unable to update packages path: /usr/lib/R/site-library.
Therefore, I did
    sudo chmod -R g+w /site-library
and then I did the same also in R folder and lib folder... However, after trying to install a package, the R error message was the same. I decide to wait for some help and I just lock my screen without turning it off. After the weekend, I back to work and there was the error message that I was running out of space in the /dev/sda3 and it suggest I have to remove the files from the bin, so I did. Then, I restarted the computer because it was quite slow. However, it never turned on again. Looking inside the recovery system from the grub menu I found that there was the /dev/sda3 (with only 46G) completely full and my other partition with almost 4T not mounted anymore. I found an error_log inside the pathway /var/log/cups of about 13G! I cancelled it and I was able to turn on again my PC with the normal boot. However, as soon as I turned it on, I received the error again, no space again in that partition and the error_log is there again (occupying almost 13G again). I have no idea what's going on and I cannot look inside the error_log with less because for some reason I received the error message also if I try to use sudo:
    sudo: error in /etc/sudo.conf, line 0 while loading plugin 'sudoers_policy'
    sudo: /usr/lib/sudo/sudoers.so must only be writable by owner
    sudo: fatal error, unable to load plugins
and I can't mount the other partition either because said that no space is left on device.
Any suggestion would be highly appreciated because at this point I am completely stuck...
Deb
