I can not change.
It seems locked.
Want to put to lower power state.
s2idle [deep]
How is this done. Google search hits discussion not all possible paths to change correctly.
UPDATE:
What people say is usually wrong:
For example, this is what happens:
$ echo s2idle | sudo tee /sys/power/mem_sleep
s2idle
$ cat /sys/power/mem_sleep
[s2idle]
Is my system broken compared to the example below that results in deep!???? Or is that a typo on their part? There is confusion like this all over the web.
Why does this fail?
echo deep | sudo tee /sys/power/mem_sleep
deep
tee: /sys/power/mem_sleep: Invalid argument
My suspsicion is that people are writing answers that trigger some latent thing ... but they do not understand what that thing is or how to change it's settings. Is it grub?
And this seems relevant https://forums.linuxmint.com/viewtopic.php?t=335139
UPDATE:
The problem appears to have been a BIOS setting. Set config power sleep state to Linux!
(OP addition): First make sure your BIOS->config->power-sleep state is correct (or whatever it is called). It should be set to Linux. Default is probably windows. Not having this set properly can block you from setting [deep].
/sys/power/mem_sleep indicates the method of suspend that will used. Availability of the various methods is system dependant.
The typical default is deep, as you have shown:
doug@s19:~$ cat /sys/power/mem_sleep
s2idle [deep]
meaning Suspend-to-RAM would be used if mem was written to /sys/power/state to suspend the system.
By changing it to s2idle:
doug@s19:~/system-info$ echo s2idle | sudo tee /sys/power/mem_sleep
s2idle
doug@s19:~/system-info$ cat /sys/power/mem_sleep
[s2idle] deep
Then Suspend-To-Idle would be used if mem was written to /sys/power/state to suspend the system.
The other way to tell the system which method of suspend to use is via the /sys/power/state itself. The options for a given system can be listed:
doug@s19:~$ cat /sys/power/state
freeze mem disk
freeze can be used for Suspend-To-Idle and mem can be used for Suspend-to-RAM, depending on the setting in /sys/power/mem_sleep.
Suspend-To-Idle will wake from suspend faster, but uses a lot more power than Suspend-to-RAM. For my test server, the mains power for a very idle system is about 37.8 Watts. Suspend-To-Idle uses about 29.4 Watts. Suspend-to-RAM uses about 2.8 Watts. I used these commands to suspend the system:
doug@s19:~$ echo freeze | sudo tee /sys/power/state
freeze
doug@s19:~$ echo mem | sudo tee /sys/power/state
mem
And pushed the power button to wake the system.
Reference.
Doug Smythies
  • 16,146
