I have a newly refurbished HP laptop:
HP HP ZBook 14u G5 Intel® Core™ i7-8650U CPU @ 1.90GHz × 8 AMD® Radeon pro wx 3100 / Mesa Intel® UHD Graphics 620 (KBL GT2)
I did a clean install of Ubuntu 22.04.2 LTS, with kernel version: 5.19.0-42-generic
And I discover that the computer does not see the wifi adapter. Here is the result of doing lshw – C network:
WARNING: you should run this program as super-user.
*-network UNCLAIMED
description: Network controller
product: Wireless 8265 / 8275
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:02:00.0
version: 78
width: 64 bits
clock: 33MHz
capabilities: cap_list
configuration: latency=0
resources: memory:ba200000-ba201fff
*-network
description: Ethernet interface
product: Ethernet Connection (4) I219-LM
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: enp0s31f6
version: 21
serial: b4:b6:86:8e:d8:17
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=5.19.0-42-generic firmware=0.1-4 latency=0 link=no multicast=yes port=twisted pair
resources: irq:127 memory:ba400000-ba41ffff
*-network
physical id: e
bus info: usb@1:2
logical name: enx025263346633
serial: 02:52:63:34:66:33
capabilities: ethernet physical
configuration: autonegotiation=off broadcast=yes driver=rndis_host driverversion=5.19.0-42-generic duplex=half firmware=RNDIS device ip=192.168.42.239 link=yes multicast=yes port=twisted pair
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
I updated and upgraded Ubuntu, and then followed the instructions on this page to install the intel driver (iwlwifi-8265-22.ucode):
https://www.linuxfordevices.com/tutorials/ubuntu/no-wi-fi-adapter-found-error
Still doesn’t work.
(New edit to my question). I found a question on Ask Ubuntu that looked like mine, involving the same intel wifi firmware:
(WiFi not working after upgrading to 22.04)
In this person's case purging the backports solved the problem. In my case, the backports are not on the computer:
sudo apt purge backport-iwlwifi-dkms
Reading package lists... Done
Building dependency tree... Done
Package 'backport-iwlwifi-dkms' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded
Could this be the problem? Also what is a backport?
When I do sudo dmesg | grep iwl
I get the following message:
[ 3.033851] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[ 3.754261] iwlwifi: probe of 0000:02:00.0 failed with error -110
Finally, per comment below, here is the the output from rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
The output from lspci -vvnn | grep -A 9 Network is
02:00.0 Network controller [0280]: Intel Corporation Wireless 8265 / 8275 [8086:24fd] (rev 78)
Subsystem: Intel Corporation Dual Band Wireless-AC 8265 [8086:0010]
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 19
Region 0: Memory at ba200000 (64-bit, non-prefetchable) [size=8K]
Capabilities: <access denied>
Kernel modules: iwlwifi
3c:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 [144d:a808] (prog-if 02 [NVM Express])
I have read through multiple different sites now and I see that there are apparently a lot of network connectivity issues with Ubuntu 22. I would not describe myself as a superuser, but I’ve been using earlier versions of Ubuntu for years, and never encountered problems like this. Also, I know that the wifi adapter works, because the computer originally came with Windows 10 and the wifi worked without a problem (This is how I downloaded the ISO for Ubuntu). Also just to confirm from the discussion in the comments, airplane mode is off.
Can anyone provide some help here?
