akshitadakahtta-MP-Laptop-18-dixxx1-$ sudo apt-get purge remove podman-docker
Reading package 1ists... Done
Calculating dependency tree... Done
 You might want to run apt Fix-broken install to correct these.
The following packages have unmet dependencies
docker-ce Depends: docker-ce-cli but it is not going to be installed
akshitadakahtta-MP-Laptop-18-dixxx1-$ sudo apt fix-broken install
Reading package lists... Done
Building dependency tree... Done
Correcting dependencies... Done
Use sudo apt autoremove to remove them.
The following additional packages will be installed: docker-ce-cli
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 191 not upgraded.
6 not fully installed or removed. 0
Need to get 0 8/13.3 MB of archives.
E: Unmet dependencies. Try 'apt fix-broken install with no packages (or specify a solution).
The following packages were automatically installed and are no longer required: bridge-utils ubuntu-fan docker-ce-cli
After this operation, 36.5 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database...
168500 Files and directories currently installed.)
Preparing to unpack...
/docker-ce-cli 5N3824.0.2-1-ubuntu. 22.04-Jammy and64.deb...
Unpacking docker-ce-cli (5:24.0.2-1-ubuntu.22.04-Jammy)... dpkgs error processing archive /var/cache/apt/archives/docker.ce-cli 5x3824.0.2-1-ubuntu.22.04-Jammy amd64.deb (unpack):
trying to overwrite /usr/bin/docker', which is also in package podman-docker 3.4.4+ds1-1ubuntu1
dpkg-debi rrari paste subprocess was killed by signal (Broken pipe)
/var/cache/apt/archives/docker-ce-cli 53824.0.2-1-ubuntu-22.04-jammy_amd64.deb
Sub-process /usr/bin/dpkg returned an error code (1)
karel
  • 122,292
  • 133
  • 301
  • 332
