230612 adding image of sure start settings Image of sure start bios settings
230611 Updating post with additional changes tried in BIOS/UEFI settings
Having issues when trying to install Ubuntu 22.04.2 (desktop) on my refurbed mini PC: HP EliteDesk 800 G3 DM i5-6500T 8 GB RAM 240 GB SSD
No dual boot, only want Ubuntu.
I created a boot-loader on a USB stick that launches fine. Double checked and the USB-stick is GPT formated. When reaching the end of installation process I received an error saying:
Unable to install GRUB in /dev/sda
Executing `grub-install /dev/sda` failed.
This is a fatal error.
I've tried changing the settings in BIOS to both these options:
Legacy Support Disable and Secure Boot Disable
Legacy Support Enable and Secure Boot Disable
Removed fast boot option from BIOS.
Clearing all Secure Boot Keys -
Removed HP Firmware Runtime Intrustion Prevention and Detection (BIOS SureStart)
Removed Dynamic Runtime Scanning of Boot Block
Resetted CMOS (twice)
Reset to factory defaults and apply changes again
Tried booting from disk both in UEFI and Legacy after installation - UEFI gets stuck on boot screen and Legacy can't find boot image (assuming this depends on me installing Ubuntu on UEFI).
When running the boot-repair-disk through the terminal in Try Ubuntu mode I receive the following output:
An error occurred during the repair.
Error: NVram is locked (Ubuntu not found in efibootmgr). Please report this message to boot.repair@gmail.com
Please write on a paper the following URL: https://paste.ubuntu.com/p/GPx5PKK9hy/
In case you still experience boot problem, indicate this URL to: boot.repair@gmail.com
Have also tried reinstalling Ubuntu a couple of times.
Edit 230529: In addition to the above I have now also tried the following:
  1. Resetting the CMOS, reinstalled, disk repair -> same errors, Unable to install GRUB, NVram locked
  2. Updated to latest HP bios 2.46, reisntalled ubuntu, disk repair -> same errors, Unable to install GRUB, NVram locked
Not sure what else I can try. Any other version of Ubuntu that might work better? Any way to manually install GRUB by-passing the NVram locked issue?
Pastebin from latest boot repair (updated 230611):
boot-repair-4ppa2056                                              [20230611_1832]
============================= Boot Repair Summary ==============================
Recommended repair: ____________________________________________________________
The default repair of the Boot-Repair utility will reinstall the grub-efi of sda2, using the following options: sda1/boot/efi Additional repair will be performed: unhide-bootmenu-10s use-standard-efi-file
Mount sda1 on /mnt/boot-sav/sda2/boot/efi No sda2/boot/efi/efi/ ubuntu/mint folder
Unhide GRUB boot menu in sda2/etc/default/grub
======================== Reinstall the grub-efi of sda2 ========================
chroot /mnt/boot-sav/sda2 grub-install --version grub-install (GRUB) 2.06-2ubuntu7.1 chroot /mnt/boot-sav/sda2 modprobe efivars
chroot /mnt/boot-sav/sda2 efibootmgr -v before grub install BootCurrent: 000E Timeout: 0 seconds BootOrder: 000E,000B,0000,0001,0002,0003,0004,0005,0006,0007,0008,0009,000F Boot0000 Startup Menu FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)....ISPH Boot0001 System Information FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0002 Bios Setup FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0003 3rd Party Option ROM Management FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0004 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0005 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0006 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0007 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0008 Boot Menu FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0009 HP Recovery FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot000B* SAMSUNG MZ7LN256HAJQ-000H1 PciRoot(0x0)/Pci(0x17,0x0)/Sata(1,0,0)N.....YM....R,Y.....ISPH Boot000C* IPV6 Network - Intel(R) Ethernet Connection (5) I219-LM PciRoot(0x0)/Pci(0x1f,0x6)/MAC(186024278b1d,0)/IPv6([::]:<->[::]:,0,0)N.....YM....R,Y.....ISPH Boot000D* IPV4 Network - Intel(R) Ethernet Connection (5) I219-LM PciRoot(0x0)/Pci(0x1f,0x6)/MAC(186024278b1d,0)/IPv4(0.0.0.00.0.0.0,0,0)N.....YM....R,Y.....ISPH Boot000E* Kingston DataTraveler 3.0 E0D55E6CE77C1731F9B60656 PciRoot(0x0)/Pci(0x14,0x0)/USB(18,0)N.....YM....R,Y.....ISPH Boot000F Network Boot FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0012 Generic USB Storage PciRoot(0x0)/Pci(0x14,0x0)/USB(3,0)N.....YM....R,Y.....ISPH Boot0013 Generic USB Storage PciRoot(0x0)/Pci(0x14,0x0)/USB(4,0)N.....YM....R,Y.....ISPH Boot0014 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(16,0)N.....YM....R,Y.....ISPH Boot0015 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(17,0)N.....YM....R,Y.....ISPH Boot0016 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(19,0)N.....YM....R,Y.....ISPH Boot0017 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(20,0)N.....YM....R,Y.....ISPH
chroot /mnt/boot-sav/sda2 uname -r 5.19.0-32-generic
chroot /mnt/boot-sav/sda2 grub-install --efi-directory=/boot/efi --target=x86_64-efi Installing for x86_64-efi platform. grub-install: error: cannot open `/boot/efi/EFI/ubuntu/grubx64.efi': No such file or directory. Exit code: 1 Error: no grub*.efi generated for Ubuntu 22.04.2 LTS. Please report this message to boot.repair@gmail.com
chroot /mnt/boot-sav/sda2 /sbin/grub-install --efi-directory=/boot/efi --target=x86_64-efi --recheck Installing for x86_64-efi platform. /sbin/grub-install: error: cannot open `/boot/efi/EFI/ubuntu/grubx64.efi': No such file or directory.
chroot /mnt/boot-sav/sda2 /sbin/grub-install --efi-directory=/boot/efi --target=x86_64-efi --no-nvram Installing for x86_64-efi platform. /sbin/grub-install: error: cannot open `/boot/efi/EFI/ubuntu/grubx64.efi': No such file or directory. --no-nvram exit code: 1 Please report this message to boot.repair@gmail.com
chroot /mnt/boot-sav/sda2 efibootmgr -v after grub install BootCurrent: 000E Timeout: 0 seconds BootOrder: 000E,000B,0000,0001,0002,0003,0004,0005,0006,0007,0008,0009,000F Boot0000 Startup Menu FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)....ISPH Boot0001 System Information FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0002 Bios Setup FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0003 3rd Party Option ROM Management FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0004 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0005 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0006 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0007 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0008 Boot Menu FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0009 HP Recovery FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot000B* SAMSUNG MZ7LN256HAJQ-000H1 PciRoot(0x0)/Pci(0x17,0x0)/Sata(1,0,0)N.....YM....R,Y.....ISPH Boot000C* IPV6 Network - Intel(R) Ethernet Connection (5) I219-LM PciRoot(0x0)/Pci(0x1f,0x6)/MAC(186024278b1d,0)/IPv6([::]:<->[::]:,0,0)N.....YM....R,Y.....ISPH Boot000D* IPV4 Network - Intel(R) Ethernet Connection (5) I219-LM PciRoot(0x0)/Pci(0x1f,0x6)/MAC(186024278b1d,0)/IPv4(0.0.0.00.0.0.0,0,0)N.....YM....R,Y.....ISPH Boot000E* Kingston DataTraveler 3.0 E0D55E6CE77C1731F9B60656 PciRoot(0x0)/Pci(0x14,0x0)/USB(18,0)N.....YM....R,Y.....ISPH Boot000F Network Boot FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0012 Generic USB Storage PciRoot(0x0)/Pci(0x14,0x0)/USB(3,0)N.....YM....R,Y.....ISPH Boot0013 Generic USB Storage PciRoot(0x0)/Pci(0x14,0x0)/USB(4,0)N.....YM....R,Y.....ISPH Boot0014 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(16,0)N.....YM....R,Y.....ISPH Boot0015 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(17,0)N.....YM....R,Y.....ISPH Boot0016 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(19,0)N.....YM....R,Y.....ISPH Boot0017 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(20,0)N.....YM....R,Y.....ISPH Error: NVram is locked (Ubuntu not found in efibootmgr). Please report this message to boot.repair@gmail.com
chroot /mnt/boot-sav/sda2 update-grub Sourcing file /etc/default/grub' Sourcing file/etc/default/grub.d/init-select.cfg' Generating grub configuration file ... Found linux image: /boot/vmlinuz-5.19.0-32-generic Found initrd image: /boot/initrd.img-5.19.0-32-generic Memtest86+ needs a 16-bit boot, that is not available on EFI, exiting Warning: os-prober will be executed to detect other bootable partitions. Its output will be used to detect bootable binaries on them and create new boot entries. cp: error reading '/mnt/boot-sav/sda1/boot/grub/grub.cfg': Input/output error cp: error reading '/mnt/boot-sav/sda1/boot/grub/grub.cfg': Input/output error cat: /mnt/boot-sav/sda1/boot/grub/grub.cfg: Input/output error
Unhide GRUB boot menu in sda2/boot/grub/grub.cfg
An error occurred during the repair. Error: NVram is locked (Ubuntu not found in efibootmgr). Please report this message to boot.repair@gmail.com
Locked-NVram detected.
============================ Boot Info After Repair ============================
=> No boot loader is installed in the MBR of /dev/sda.
sda1: __________________________________________________________________________
File system:       vfat
Boot sector type:  FAT32
Boot sector info:  According to the info in the boot sector, sda1 has
                   7811072 sectors.. But according to the info from the
                   partition table, it has 1048575 sectors.
Operating System:
Boot files:        /boot/grub/grub.cfg /efi/BOOT/grubx64.efi
                   /efi/BOOT/mmx64.efi
sda2: __________________________________________________________________________
File system:       ext4
Boot sector type:  -
Boot sector info:
Operating System:  Ubuntu 22.04.2 LTS
Boot files:        /boot/grub/grub.cfg /etc/fstab /etc/default/grub
sdb: ___________________________________________________________________________
File system:       iso9660
Boot sector type:  Grub2 (v1.99-2.00)
Boot sector info:  Grub2 (v1.99-2.00) is installed in the boot sector of
                   sdb and looks at sector 0 of the same hard drive for
                   core.img, but core.img can not be found at this
                   location.
Mounting failed:   mount: /mnt/BootInfo/FD/sdb: /dev/sdb already mounted or mount point busy.
================================ 1 OS detected =================================
OS#1: Ubuntu 22.04.2 LTS on sda2
================================ Host/Hardware =================================
CPU architecture: 64-bit Video: HD Graphics 530 from Intel Corporation Live-session OS is Ubuntu 64-bit (Ubuntu 22.04.2 LTS, jammy, x86_64)
===================================== UEFI =====================================
BIOS/UEFI firmware: P21 Ver. 02.46(2.46) from HP The firmware is EFI-compatible, and is set in EFI-mode for this live-session. SecureBoot disabled (confirmed by mokutil). BootCurrent: 000E Timeout: 0 seconds BootOrder: 000E,000B,0000,0001,0002,0003,0004,0005,0006,0007,0008,0009,000F Boot0000 Startup Menu FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)....ISPH Boot0001 System Information FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0002 Bios Setup FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0003 3rd Party Option ROM Management FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0004 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0005 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0006 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0007 System Diagnostics FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0008 Boot Menu FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0009 HP Recovery FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot000B* SAMSUNG MZ7LN256HAJQ-000H1 PciRoot(0x0)/Pci(0x17,0x0)/Sata(1,0,0)N.....YM....R,Y.....ISPH Boot000C* IPV6 Network - Intel(R) Ethernet Connection (5) I219-LM PciRoot(0x0)/Pci(0x1f,0x6)/MAC(186024278b1d,0)/IPv6([::]:<->[::]:,0,0)N.....YM....R,Y.....ISPH Boot000D* IPV4 Network - Intel(R) Ethernet Connection (5) I219-LM PciRoot(0x0)/Pci(0x1f,0x6)/MAC(186024278b1d,0)/IPv4(0.0.0.00.0.0.0,0,0)N.....YM....R,Y.....ISPH Boot000E* Kingston DataTraveler 3.0 E0D55E6CE77C1731F9B60656 PciRoot(0x0)/Pci(0x14,0x0)/USB(18,0)N.....YM....R,Y.....ISPH Boot000F Network Boot FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(9d8243e8-8381-453d-aceb-c350ee7757ca)......ISPH Boot0012 Generic USB Storage PciRoot(0x0)/Pci(0x14,0x0)/USB(3,0)N.....YM....R,Y.....ISPH Boot0013 Generic USB Storage PciRoot(0x0)/Pci(0x14,0x0)/USB(4,0)N.....YM....R,Y.....ISPH Boot0014 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(16,0)N.....YM....R,Y.....ISPH Boot0015 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(17,0)N.....YM....R,Y.....ISPH Boot0016 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(19,0)N.....YM....R,Y.....ISPH Boot0017 PHIYO USBTB3-12 123456789010 PciRoot(0x0)/Pci(0x14,0x0)/USB(20,0)N.....YM....R,Y.....ISPH
bfd3f5550a8a28a1021abe2b838e3b6a sda1/BOOT/grubx64.efi dc3c47be2f78a78e5e57d097ae6c5c84 sda1/BOOT/mmx64.efi 78415fb8fb9b909f8029858113f1335f sda1/BOOT/BOOTx64.efi
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
sda : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, has-os, no-wind, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
sda1 : no-os, 64, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far sda2 : is-os, 64, apt-get, signed grub-pc grub-efi , grub2, grub-install, grubenv-ok, update-grub, farbios
Partitions info (2/3): _________________________________________________________
sda1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot sda2 : isnotESP, fstab-has-goodEFI, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
Partitions info (3/3): _________________________________________________________
sda1 : not--sepboot, no-kernel, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, no--grub.d, sda sda2 : not--sepboot, with-boot, fstab-without-boot, not-sep-usr, with--usr, fstab-without-usr, std-grub.d, sda
fdisk -l (filtered): ___________________________________________________________
Disk sda: 238.47 GiB, 256060514304 bytes, 500118192 sectors Disk identifier: 96F12D4F-7885-4E13-BFED-53426A3F18CD Start End Sectors Size Type sda1 2048 1050623 1048576 512M EFI System sda2 1050624 500117503 499066880 238G Linux filesystem Disk sdb: 28.87 GiB, 30995907072 bytes, 60538881 sectors Disk identifier: A0891D7E-B930-4513-94D9-F629DBD637B2 Start End Sectors Size Type sdb1 64 9613459 9613396 4.6G Microsoft basic data sdb2 9613460 9623527 10068 4.9M EFI System sdb3 9623528 9624127 600 300K Microsoft basic data sdb4 9625600 60538817 50913218 24.3G Linux filesystem
parted -lm (filtered): _________________________________________________________
sda:256GB:scsi:512:4096:gpt:ATA SAMSUNG MZ7LN256:; 1:1049kB:538MB:537MB:fat32:EFI System Partition:boot, esp; 2:538MB:256GB:256GB:ext4::; sdb:31.0GB:scsi:512:512:gpt:Kingston DataTraveler 3.0:; 1:32.8kB:4922MB:4922MB::ISO9660:hidden, msftdata; 2:4922MB:4927MB:5155kB::Appended2:boot, esp; 3:4927MB:4928MB:307kB::Gap1:hidden, msftdata; 4:4928MB:31.0GB:26.1GB:ext4::;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL sda
├─sda1 vfat 56CC-DEF5 67426988-6317-42b4-9c40-4530011a5cf6 EFI System Partition └─sda2 ext4 c536fd40-b9ca-4759-88d1-b3bd6ef6b1a1 b193bf07-b32f-4eb8-81df-10f1f104182c
sdb iso9660 2023-02-23-04-13-44-00 Ubuntu 22.04.2 LTS amd64 ├─sdb1 iso9660 2023-02-23-04-13-44-00 a0891d7e-b930-4513-94d8-f629dbd637b2 Ubuntu 22.04.2 LTS amd64 ISO9660 ├─sdb2 vfat F7DB-4D56 a0891d7e-b930-4513-94db-f629dbd637b2 ESP Appended2 ├─sdb3 a0891d7e-b930-4513-94da-f629dbd637b2 Gap1 └─sdb4 ext4 9ef377e8-76c4-4b9c-8c26-e4738a2dd8df 0d7ad038-c798-234d-b090-1211e3d3c043 writable
Mount points (filtered): _______________________________________________________
                                                           Avail Use% Mounted on
/dev/disk/by-label/writable[/install-logs-2022-09-09.0/crash] 22.5G 0% /var/crash /dev/disk/by-label/writable[/install-logs-2022-09-09.0/log] 22.5G 0% /var/log /dev/sda1 491.1M 87% /mnt/boot-sav/sda1 /dev/sda2 212.2G 4% /mnt/boot-sav/sda2 /dev/sdb1 0 100% /cdrom
Mount options (filtered): ______________________________________________________
====================== sda1/boot/grub/grub.cfg (filtered) ======================
==================== sda1: Location of files loaded by Grub ====================
       GiB - GB             File                                 Fragment(s)
        ?? = ??             boot/grub/grub.cfg                             1
====================== sda2/boot/grub/grub.cfg (filtered) ======================
Ubuntu c536fd40-b9ca-4759-88d1-b3bd6ef6b1a1 Ubuntu, with Linux 5.19.0-32-generic c536fd40-b9ca-4759-88d1-b3bd6ef6b1a1
END /etc/grub.d/30_os-prober
END /etc/grub.d/30_uefi-firmware
========================== sda2/etc/fstab (filtered) ===========================
<file system> <mount point> <type> <options> <dump> <pass>
/ was on /dev/sda2 during installation
UUID=c536fd40-b9ca-4759-88d1-b3bd6ef6b1a1 / ext4 errors=remount-ro 0 1
/boot/efi was on /dev/sda1 during installation
UUID=56CC-DEF5 /boot/efi vfat umask=0077 0 1 /swapfile none swap sw 0 0
======================= sda2/etc/default/grub (filtered) =======================
GRUB_DEFAULT=0 GRUB_TIMEOUT_STYLE=menu GRUB_TIMEOUT=10 GRUB_DISTRIBUTOR=lsb_release -i -s 2&gt; /dev/null || echo Debian GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" GRUB_CMDLINE_LINUX="" GRUB_DISABLE_OS_PROBER=false
==================== sda2: Location of files loaded by Grub ====================
236.426387787 = 253.860900864 boot/vmlinuz 1 236.426387787 = 253.860900864 boot/vmlinuz-5.19.0-32-generic 1 237.169620514 = 254.658940928 boot/initrd.img 1 237.169620514 = 254.658940928 boot/initrd.img-5.19.0-32-generic 1 237.169620514 = 254.658940928 boot/initrd.img.old 1
===================== sda2: ls -l /etc/grub.d/ (filtered) ======================
-rwxr-xr-x 1 root root 18683 Dec 2 2022 10_linux -rwxr-xr-x 1 root root 43031 Dec 2 2022 10_linux_zfs -rwxr-xr-x 1 root root 14180 Dec 2 2022 20_linux_xen -rwxr-xr-x 1 root root 13369 Dec 2 2022 30_os-prober -rwxr-xr-x 1 root root 1372 Dec 2 2022 30_uefi-firmware -rwxr-xr-x 1 root root 700 Sep 20 2022 35_fwupd -rwxr-xr-x 1 root root 214 Dec 2 2022 40_custom -rwxr-xr-x 1 root root 215 Dec 2 2022 41_custom
What else can I do here? Anything manually I can try?
Following this article to reset the CMOS using ubuntu terminal solved my problem. I installed ubuntu on my flash then i boot into the flash. After that, choose "try or install ubuntu" then "try ubuntu". Then i followed the steps found in this article
