I'm not a Linux user. This problem occurred after I updated Ubuntu 22.4.2 to the new version that probably came out yesterday on may/22/2023. I'm using Hyper-V Virtual Machine. Everything freezes after login. nothing works and there is nothing except the wallpaper on the screen. I can use key combinations to open that black command-based page with ctrl + alt + f1 and ctrl + alt + f3. it asks me for username and password. It does not accept credentials though. I think it freezes mid work. I have also tried locking the screen with ctrl + alt + f1 and login again. But after a few seconds of working. it freezes again. I have restarted several times and it has not worked. I don't have a GPU on my pc so it's not the GPU driver issue with Nvidia that some may say. I also used this Link:( Updated from 16.04 to 16.10; the keyboard and mouse no longer works after getting to the lock screen ) to solve the issue. the problem is using SHIFT does not work at startup. So, I tried using those few seconds to Enter the Command:( apt install xserver-xorg-input-all ). and it said I already have it installed. The same problem has happened on my laptop too. after the update nothing works. what should I do? I have no restore points either. If there is a rollback option, please guide me. the update has come out very recently. I don't know the number. But I'm sure you guys know.
Asked
Active
Viewed 1,533 times
It does look like this is a recent kernel update. I've got around this by installing and using kernel 5.19.0-41-generic.
From frozen screen use CTRL+ALT+F3 to jump to text mode and login. You can then use following to install the lower kernel sudo apt install linux-image-5.19.0-41-generic.
You might also need to adjust your grub settings so you can select the kernel at boot time.
Sudo nano /etc/default/grub
I then changed
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
Once you save a quick I then use sudo update-grub
and then sudo reboot
You should then have an Advanced options for Ubuntu that you can choose and from there you can select the 5.19.0-41 Kernel.
Can't guarantee it won't break anything down the line but it's got me into my test Ubuntu VM.
Graham Read
- 21
