i am trying to install the epson printer utilities with the hope i could use the Power Ink Flushing functionality since my printer L3151 will only print black and magenta
this is the error i get when trying to install the .deb package i downloaded from the espon website
$ sudo dpkg -i ~/Downloads/epson-printer-utility_1.1.1-1lsb3.2_i386.deb
Selecting previously unselected package epson-printer-utility:i386.
(Reading database ... 330447 files and directories currently installed.)
Preparing to unpack .../epson-printer-utility_1.1.1-1lsb3.2_i386.deb ...
Unpacking epson-printer-utility:i386 (1.1.1-1lsb3.2) ...
dpkg: dependency problems prevent configuration of epson-printer-utility:i386:
 epson-printer-utility:i386 depends on lsb (>= 3.2).
dpkg: error processing package epson-printer-utility:i386 (--install): dependency problems - leaving unconfigured Errors were encountered while processing: epson-printer-utility:i386
$ lsb_release -a
LSB Version:    core-11.1.0ubuntu2-noarch:printing-11.1.0ubuntu2-noarch:security-11.1.0ubuntu2-noarch
Distributor ID: Ubuntu
Description:    Ubuntu 20.04.6 LTS
Release:    20.04
Codename:   focal
i don't understand why i am getting this error :( i did some digging around but nothing useful appeared
guiverc
  • 33,561
alex
  • 103
This may be a 32-bit vs 64-bit issue, as you're trying to install the 32-bit drivers (i386) on a 64-bit installation of Ubuntu. As a result, the dependency chain may be looking for a large number of 32-bit libraries, which are no longer available.
Using the documentation from Epson regarding this package, the utility is installed like this:
  1. Download the 64-bit package from the Epson website. This would be the file named:
    epson-printer-utility_1.1.1-1lsb3.2_amd64.deb
  2. Install the required LSB package:
    1. Open Terminal (if it's not already open)
    2. Make sure apt is updated:
      sudo apt update
    3. Install the package:
      sudo apt install lsb
  3. Install the .deb package that was downloaded in Step 1:
    sudo dpkg -i epson-printer-utility_1.1.1-1lsb3.2_amd64.deb
  4. Launch the utility:
I do not have an Epson printer to test the effectiveness of the utility, but the first four steps will work just fine on Ubuntu 20.04 and the newer 22.04.
matigo
  • 24,752
  • 50
  • 79
-1
Whenever you use dpkg directly to install or remove packages, it may fail with something, like dependencies in your case. What you can try to do is use apt to resolve the issue:
sudo apt -f install
It should install the packages that are required for the one you tried to install with dpkg, and lastly do just that if the requirements were satisfied.
